November 22, 2024, 02:01:01 pm *
Pages: 1 [2] 3 4 5 6 7  All
Author Topic: WiFi Remote  (Read 98028 times)
« Reply #15 on: May 16, 2009, 12:55:44 pm »
Yeah, that's about what the problem comes down to.
Your best option may be to go to a shop (like Paradigit for sure will be in your neighbourhood) and ask there, so they immediately can show you.
I really gave up on arranging for this via the Internet only.
Btw you are correct; via AutoHotkey anything can be arranged for, meaning whatever code the software provides can be dealt with by AutoHotkey. However, it is another step, and software which just can turn the whatever IR code into "your command" directly (like Alt-U) avoids amending the XX.ahk configuration file.
Again, I am very sorry that I did not arrange for this myself, but my take would really be as good as yours (anyone's), and I really can't spend all that time on this stupid thing.
Btw, even serial connected thingy's promise not to work right out of the box, unless you can get one really meant for it. However, those (as far as I saw) work with WinLIRC, and with this as a variable in the equation ... you could say even I find it too difficult. And note it is just about this : more than one variable, and either can cause things not to work. So as long as you don't know one of them (when there are two), you just won't get there. Besides, how old is WinLIRC ? (without development).
But thanks Roy.
« Reply #16 on: May 16, 2009, 01:19:15 pm »
Something will come up, sooner or later,
Nothing is impossible.
No rush on this subject, but it would be so need,
To push 1 button on my remote and a string of commands does anything I wan't it to do.
grtz
PS:it's indeed a stupid difficult subject
« Reply #17 on: July 17, 2009, 09:47:17 pm »
Recently I stumbled on a program that allows you to control your PC with a mobile (smart)phone.
It works with bluetooth and Wifi.
Every program needs some javascript to control it.
With mediaplayer it works out of the box and gives you even the albumart on the phone!
You can find it at salling.com.
Maybe someone can make an awsome js-script for XXHE?
Gerard (A).
« Reply #18 on: July 18, 2009, 01:37:55 am »
Coincedence,
Will test next week a (hopefully working) remote control solution.
maybe just maybe, it works.
 Grin
« Reply #19 on: July 18, 2009, 03:08:52 pm »
It works...
Made a script with all the ALT-commands.
In attended mode with a Nokia N95 XXHE responds perfect. Happy
In unattended mode not. unhappy
I'm trying to make the script nicer and if there is interest I'll post it here.
« Reply #20 on: July 18, 2009, 07:14:35 pm »
and problably effect soundquality, unhappy
When using WiFi or bluetooth.
grtz
« Reply #21 on: July 18, 2009, 09:51:30 pm »
Wifi is going through the network, not directly.
Maybe the radiation is bad, but then what to do about the neighbours wifi and bluetooth and the fridge or the airco in these warm days?
I don't hear the difference, but then I enjoy analog too!
The scripting/receiving program uses some cpu/memory but then maybe it is time to use different processorparts of the cpu more strictly?
BTW. In unattended it works too, but of course then you have to start auto-hotkey.
I added the script.
* XXHighEnd_Remote.js (4.28 KB - downloaded 524 times.)
* XXHighEnd_Remote.xml (0.39 KB - downloaded 655 times.)
« Reply #22 on: July 19, 2009, 07:11:37 am »
I am sure going to try this. Looks good so far !
Memory yes, but cpu or anything only when it's asked to do something. This is because this kind of software (when made how it should) just gets "called" and does not "poll" (the latter would use cpu (although still hardly measurable) and may influence sound).
Thanks Gerard,
« Reply #23 on: July 19, 2009, 08:13:48 am »
I added the script.
Thanks for this effort.  This is just in time for me.  I've been watching the smart phones evolve and waiting until I was happy with all the features.  Finally I think BlackBerry has come out with one for my carrier that I'll jump into. (called The Tour 9630 in the US).  I'll give the script a try later.  I always play unattended with auto-hotkey.
« Reply #24 on: July 19, 2009, 10:37:41 pm »
What i need instead, is some way to communicate with iMON (one of the most common IR "multimedia" receiver). That way i can use my normal remote (the Harmony).
« Reply #25 on: July 20, 2009, 10:13:46 pm »
Telstar, you didn't read the forum at soundgraph.com or simon.com, everybody agrees the IMON-panel  is useless.
I have one in my htpc and cannot understand why they made such a mess of what looks like a great idea.
My  2 cents... unhappy
Well if your watch is broken you can see the time on your PC (if you can read the strange font...and don't wait to long.. etc.etc.)
« Reply #26 on: July 21, 2009, 03:33:42 am »
Oh Yeah Baby,
Just controlled XX by IR-remote (true autohotkey, macro's). Tongue
It did Alt-n !!!! - Next  (in Unattended)
Its learning most of my IR-remote buttons. hehehehe
Can control anything, I guess.
And best of all, it works on W7.
I come back on this its late now.
grtZZZZZ
« Last Edit: July 21, 2009, 04:23:34 pm by AUDIODIDAKT » Logged
« Reply #27 on: July 21, 2009, 02:05:02 pm »
Uhm i think i was wrong. I have IR Trans with my case.
My only fault is that i havent assembled the pc yet, waiting for the mainboard.
This is what i have:
http://www.origenae.co.kr/en/accessory_vf110.htm
« Reply #28 on: July 21, 2009, 04:19:20 pm »
Imon bay is a no go.
You can not even read the screen.
Garbage that what it is. Wink
grtz
« Reply #29 on: July 21, 2009, 05:27:14 pm »
Really Nice Telstar,
This is how it should be done!
