November 23, 2024, 08:29:38 pm *
Author Topic: Error Msg  (Read 10503 times)
« on: March 01, 2009, 12:23:51 pm »
Hi Peter - I have just downloaded 09x3. When the player finishes playing a track and is moving on to the next track the error message attached is shown and playback stops. When I press OK in the error message the next track then plays. This error happens not all the time but most of the time.
All the best
« Reply #1 on: March 01, 2009, 12:46:08 pm »
But does this happen at each occasion ?
And what happens with Unattended ?
« Reply #2 on: March 02, 2009, 10:46:13 am »
Unnattended is greyed out (can't use engine 3 does not work in my system). I use engine 1 & engine 2 and this problem happens with both. It happens most of the time but not every time.
I do not have this problem with 09w5 which is the version I was using
« Reply #3 on: March 02, 2009, 02:06:11 pm »
Aha ... thank you.
« Reply #4 on: March 02, 2009, 10:19:29 pm »
Solved in 0.9x-4.
Note that I discovered along with it a ChangeWP error, hence the Wallpaper won''t work anymore for Engine #1 and #2. I will try to solve that too.
Leo
« Reply #5 on: March 03, 2009, 10:37:20 pm »
Another error. Suddenly XX refuses to play, and I get a Windows message about closing the program or look for a solution on the net.
I have enclosed the logfiles.
Very strange behavior as i did not change anything and it had been playing very nicely all evening.
* X3-20090303-221924.log (0.39 KB - downloaded 499 times.)
Leo
« Reply #6 on: March 03, 2009, 10:38:57 pm »
and the other file
* XX-20090303-221908.log (5.47 KB - downloaded 507 times.)
Leo
« Reply #7 on: March 03, 2009, 10:41:26 pm »
I have restarted the computer 3 times.....
oops there is a rotten file in the playlist....
excuse me
« Reply #8 on: March 03, 2009, 11:44:40 pm »
No Leo, my fault at all times. I must investigate it, but it will be my task to prevent from these things.
Page created in 0.919 seconds with 19 queries.
