November 23, 2024, 09:41:36 am *
Author Topic: X3 errors still  (Read 16149 times)
« on: February 20, 2009, 06:37:26 pm »
I still get random errors when playing with the following .NET mask.
Was the same with X1 and X2.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: DragDrop registration did not succeed. ---> System.Threading.ThreadStateException: Current thread must be set to single thread apartment (STA) mode before OLE calls can be made. Ensure that your Main function has STAThreadAttribute marked on it.
   at System.Windows.Forms.Control.SetAcceptDrops(Boolean accept)
   --- End of inner exception stack trace ---
   at System.Windows.Forms.Control.OnHandleCreated(EventArgs e)
   at System.Windows.Forms.DataGrid.OnHandleCreated(EventArgs e)
   at System.Windows.Forms.Control.WmCreate(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
XXHighEnd
    Assembly Version: 1.0.3336.35642
    Win32 Version: 1.0.3336.35642
    CodeBase: file:///E:/Downloads/Installer/Software/Music/XXhighend/09-x3/XXHighEnd.exe
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.1434 (REDBITS.050727-1400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Microsoft.DirectX.DirectSound
    Assembly Version: 1.0.2902.0
    Win32 Version: 5.04.00.2904
    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX.DirectSound/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.DirectSound.dll
System.Data
    CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
SoundsLike
    Assembly Version: 1.1.2624.38754
    Win32 Version: 1.1.2624.38754
    CodeBase: file:///E:/Downloads/Installer/Software/Music/XXhighend/09-x3/SoundsLike.DLL
LogicNP.FolderView
    Assembly Version: 10.0.0.0
    Win32 Version: 10.0.0.0
    CodeBase: file:///E:/Downloads/Installer/Software/Music/XXhighend/09-x3/LogicNP.FolderView.DLL
System.Management
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Microsoft.DirectX
    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
« Reply #1 on: February 20, 2009, 07:55:12 pm »
Hi Telstar,
I did not know of these, although I know what kind of stuff can incur for it. But I really must know at what occasion(s) this happens.
I know they (usually) can't be copied at will. So if it happens again, can you please tell me what you did ?
Leaving the loggin on for a while is another idea. Might you not recognize what you did to incur for it, you can always post the most recent XX logfile (X3 logfile is not necessary).
« Reply #2 on: February 20, 2009, 08:04:49 pm »
Hi Telstar,
That's why you didnt fix em Happy
I did keep it logging, and the log doesnt say much. It happens absolutely at random, not always with the same file.
I think it has something to do with mp3 tracks.
Here is a part of the logs, but they dont seem to say much to me:
16:44:38.2079468 Trackload started (init)
16:44:38.2099468 Track Name : UnicodeTrack0001.wav
16:44:38.2099468 Data Parameter : :DATA:E:\Music\80s\COREYH~1\CO6830~1.MP3:TIME:4:38.58:BITRATE:0128:TYPE:MP3:START::CV:E:\Music\80s\COREYH~1\folder.jpg
16:44:38.8119468 Music file found : UnicodeTrack0001.wav
16:44:39.9559468 Track ready to play ---------------------
And it just stops there.
This maybe is the only one that says a bit more, altough in other logs it kept playing even if xxdat001 didnt exist:
16:48:16.2079468 Trackload started (init)
16:48:16.2099468 Track Name : UnicodeTrack0001.wav
16:48:16.2099468 Data Parameter : :DATA:E:\Music\80s\COREYH~1\CO6830~1.MP3:TIME:4:38.58:BITRATE:0128:TYPE:MP3:START::CV:E:\Music\80s\COREYH~1\folder.jpg
16:48:16.7819468 Music file found : UnicodeTrack0001.wav
16:48:17.9269468 Track ready to play ---------------------
16:52:49.0169468 Trackload started
16:52:49.0189468 Get file for track
16:52:49.0189468 XXDat0001.dat does not exist
PS: Attended/mp3, xxhe window minimized, computer used to do other stuff (outlook, firefox, etc)
« Reply #3 on: February 21, 2009, 08:09:17 am »
Hmm ... so this may happen when you restore to the normal size ? or when you do Alt-Tab to reacivate XX perhaps ?
« Reply #4 on: February 24, 2009, 01:33:07 pm »
Attended/flac, after reinstall (i.e deleted folder, reunzipped and recreated temp folder)
No, it does it by itself, when i have it minimized and i'm using firefox or office programs.
I noticed that when a track change xxhe gets the focus and the name in the taskbar glows. I'm not sure if it does all the times, though.
I do not use unattended on this machine because when it crashes it does not restore my background Wink
Also, yesterday I did some playback under Windows7, build7000 x32 (compared to my vista which is 64 bit).
Exactly the same behaviour.
Moreover, some tracks with japanese characters simply make xxengine3.exe crash.
« Reply #5 on: February 24, 2009, 03:24:03 pm »
Ah ... yes, this is very helpful. Not that I know where to begin looking, if I'd only be able to copy this behaviour. I see chances for that now.
Thanks !
PS:
I only had this once, and you can bet I have some crashes !!
Might you be able to tell what kind of crash causes this, please let me know.
Btw, do not forget that the "I" button restores desktop Icons but also implies some internal consistency when used at the right time.
Lastly, I too can have the situation that the wallpaper has vanished, but bringing up XX and quit it (or the other way around) always restores things. If not, this is not good and requires attention from me.
Just to let you know ...
« Reply #6 on: February 27, 2009, 11:04:19 pm »
Just a note: the engine3 crash was due to japanese characters (i re-ripped that cd with english titles).
The drag and drop error is completely random instead, happens both in vista x64 and in w7 b7000 x32.
My only suggestion to debug is to install the SP1, which you should have long ago Wink))
« Reply #7 on: February 27, 2009, 11:11:53 pm »
... which got revertes because of the SSD problems ! unhappy
So, still (or again) at SP0 here ...
« Reply #8 on: March 02, 2009, 05:27:15 pm »
But now that you dont have a SSD anymore? Happy
« Reply #9 on: March 02, 2009, 05:49:14 pm »
I still have it, but haven't used it for two months or so. But I will again, but then a good one ... (Intel).
« Reply #10 on: March 25, 2009, 11:28:51 am »
Telstar,
You beautifully provided those log files, but as it turns out I need those from XXHighEnd (the XX files). Can you please :
Turn on logging, let it happen again, and at the moment the error message is on the screen, draw a copy of the XX log file and post that.
Thanks !
« Reply #11 on: March 25, 2009, 06:08:17 pm »
Telstar,
Thanks !
I posted the XX logs in this post:
http://www.phasure.com/index.php?topic=744.msg5458#msg5458
But as you can see they dont say anytning.
i'll play for a while now until i get the error and i'll post the XX logs again.
« Reply #12 on: March 25, 2009, 06:26:56 pm »
Here you go.
18:24:24.9507178 : Determine selection for paremeter : 29 Total Track Count : 29
18:24:24.9517178 : Minutes:Seconds:PartialSeconds from reboot : 24:41.85
18:24:24.9517178 : Initializing playback for E:\Music\ALTERNATIVE\Chris Garneau\05 So Far.mp3
18:24:24.9587178 : Supporting data file : XXDat0001.dat
18:24:24.9597178 : Attended playback initiated
18:24:24.9597178 : DAC needs 32 bits
18:24:24.9597178 : Playing initiated on device 1
18:24:24.9607178 : Crack Detect is applied
18:24:24.9607178 : Mem box is not applied
18:24:24.9617178 : Less Dynamics is not applied
18:24:24.9617178 : Format Change is allowed
18:24:24.9617178 : Do not show Running Time OSD
18:24:24.9627178 : Short path initiated for UniCode : E:\Music\ALTERN~1\CHRISG~1\05SOFA~1.MP3
18:24:24.9627178 : Short path applied for UniCode : E:\Music\ALTERN~1\CHRISG~1\05SOFA~1.MP3
18:24:24.9637178 : Short path result for UniCode : E:\Music\ALTERN~1\CHRISG~1\05SOFA~1.MP3
18:24:24.9647178 : Track time initiated : 4:23.44
18:24:24.9647178 : Track start initiated :
18:24:24.9657178 : UniCode track initiated : UnicodeTrack0001.wav
18:24:24.9657178 : RP ReorganizeProxy for E:\Music\ALTERNATIVE\Chris Garneau\05 So Far.mp3 - 5
18:24:24.9667178 : RP Treating DatNumber 1
18:24:24.9667178 : RP Proceeding with DatType .dao
18:24:24.9677178 : RP UnicodeTrack File Name : UnicodeTrack0001.wav
18:24:24.9687178 : Start Conversion
18:24:24.9697178 : Wait for finish of processor 1
18:24:24.9697178 : Starting conversion thread for processor 1
18:24:24.9707178 : Attended Playback waiting for conversion to finish for processor 1
18:24:24.9707178 : Conversion start for processor 1
18:24:24.9717178 : MP3 decoding start for processor 1
18:24:27.0237178 : MP3 decoding applied for processor 1
18:24:27.0257178 : Attributes (1) set for processor 1
18:24:27.0257178 : Attributes (2) set for processor 1
18:24:27.0737178 : Attended Playback finished waiting for conversion for processor 1
18:24:27.0737178 : Logging is applied
18:24:27.0747178 : Split file at size : 100
18:24:27.0757178 : Slider position :    0
18:24:27.0757178 : Play at position : 0
18:24:27.0767178 : TimeStart : 0
18:24:27.0767178 : Bytes per second : 176400
18:24:27.0777178 : TimeLength : 46470816
18:24:27.0787178 : Done with Unattended loop
18:24:34.0227178 : XXEngine3 started message received --------------------
18:24:34.0237178 : GetTracksWaitTime : 253439
18:24:34.0527178 : Show CoverArt in thread : E:\Music\ALTERNATIVE\Chris Garneau\05 So Far.mp3
18:24:34.0527178 : LastPathLoaded vs. CurrentPath E:\Music\ALTERNATIVE\Chris Garneau\ - E:\Music\ALTERNATIVE\Chris Garneau\
18:24:48.2137178 : Stop initiated
18:24:48.3447178 : XXEngine3 Externally stopped
« Reply #13 on: March 29, 2009, 05:31:44 pm »
Ok, I can't get it done to copy the behaviour, but I changed everything which is related to threading. This will be in next version, 0.9x-6.
« Reply #14 on: April 06, 2009, 04:47:09 pm »
This appeared to happen with the demo version only, and has been solved. It will be in 0.9x-7.
Page created in 0.109 seconds with 19 queries.
