April 05, 2025, 03:47:34 pm *
Pages: [1] 2 3  All
Author Topic: XXHighEnd-08a - feedback  (Read 40960 times)
Chris V
« on: June 19, 2007, 08:10:55 pm »
Engine #1 and #2 playing OK but nothing from engine #3. The track indicator at the bottom is not moving, but I have no error messages at all.
Have tried putting ticks in 'double' and 'upsample' but still no sound. dntknw
Then to SW1X Signature DAC
« Reply #1 on: June 19, 2007, 09:34:26 pm »
So far you are the first to respond, so I can't tell really.
I must say honestly though that I couldn't test it u/i playing, because the laptop I now use for testing fails earlier, but then with an error message.
Otoh, you have the Fireface, and that just should be working (but again, not tested with that laptop, because I just can't -> no Firewire connection).
Then, did you look at the Fireface Mixer (various settings) in order to see something move there ?
Remember, you can be just right, because I didn't hear back from anyone as off yet ...
Btw, if Engine#2 plays, I think you selected the appropriate Fireface "mix". Hmm ...
Jack
« Reply #2 on: June 19, 2007, 09:47:09 pm »
Hi Guys
I have everything I had with previous version PLUS #3. However when I select Double or UpSmp I get 2 errors. 1st. "Device(currently)does not support/allow Exclusive use.It will not be bit perfect!" Hit OK. & 2nd. "Device cannot be allocated because of not matching sample rate(?)."
Over to you....
Jack
Jack
« Reply #3 on: June 19, 2007, 09:51:30 pm »
Hi Peter
Also, just noticed, even after the messages the track bar is moving, but no sound.
Regards Jack
« Reply #4 on: June 19, 2007, 09:52:30 pm »
Hi Jack, thanks.
But do you say that without double/upsampling you do have sound ? (#3)
Jack
« Reply #5 on: June 19, 2007, 09:55:36 pm »
Yes I have sound!
Jack
« Reply #6 on: June 19, 2007, 10:15:10 pm »
Ok, a bit of a superfluous question : your DAC (and/or soundcard) can do 88K2 ? (at 16 bits)
Jack
« Reply #7 on: June 19, 2007, 10:19:28 pm »
TwinDac+
Jack
Chris V
« Reply #8 on: June 19, 2007, 10:31:04 pm »
Just downloaded the software 8a again and now engine #3 is working  drinks drinks
F.....g computers wacko
Jack
« Reply #9 on: June 19, 2007, 10:41:53 pm »
I'm using USB, on reviewing the Twindac specs I get up to 48 khz up to 16 bit. So that explains that! Sorry If I misled you!
Firefaceless Jack
hal3101
« Reply #10 on: June 19, 2007, 10:42:51 pm »
Sound from engine #3 now ok. The sound is really really spacious and dynamic. Probably the best I have ever heard. No doubling or upsampling as I am using a 44.1k usb nos dac (dddac). But there seems to be a problem in periods with high dynamics especially piano dynamic. I sometimes get noise or crackles in the sound. Wery little but it is there. I have not noticed this problem with engine #2 and #1. No problems with cpu capacity or memory (2 giga)
TorH
Home build pc, Intel Dual core 4300 1.8 GHz , Vista Business, 2 GB RAM, one 500 GB harddisk, Q1 -3 with checked invert, appoint processor cores checked, Engine 3 checked, Double and upsamp NOT checked -> USB DDDAC -> TVC -> 300B -> Oris 200
« Reply #11 on: June 19, 2007, 10:50:07 pm »
Ok, thank you all for your trial and error miseries !
I 'll try to look into your further notes.
For TorH : Please try to analyse what could be causing this. I will try USB myself once more. But maybe more importantly :
Klaus ... do you have the same experience with your DDDAC ? and what about SPDIF ? (IIRC you have that)
Chris V
« Reply #12 on: June 19, 2007, 11:35:17 pm »
Update
Its early days but I think my preference is for #3 doubled good.
Both the upsampling and doubling work fine, showing 88.2 on my TacT.
Still getting some glitches/dropouts particularly at high sampling rates. Beginning to think this is a problem with Vista. I will continue to investigate.
Twice when XX timed out, it rebooted my computer stop - first time any of the engines have done this.
« Reply #13 on: June 19, 2007, 11:46:55 pm »
Hmm ... Chris ... From theory that is possible, because of my earlier expression (somewhere) that after this timeout it shouldn't present an error. So ... as long as it does while I don't understand why ... it could cause anything. I myself never experienced a reboot, but I think it just can.
Don't try to find the cause of this for now, and just blame me.  evil
About the glitches ... you know my opinion about that ... just take your time to get a grasp of that somehow.
« Reply #14 on: June 19, 2007, 11:58:27 pm »
My PC rebooted today once and that was when I was playing with the sample settings in the FirFace configuration menu with XX still playing. Everytime you change something on the fireface or XX settings then do restart XX to prevent that the fireface drivers get confused and trigger a blue/black screen and a reboot...
128 samples and all works well onder Vista and XX #3 (single, double and upsampling). No skipping here....
Do you use the latest fireface software driver and also the latest hardware driver (updating the fireface itself)?
Pages: [1] 2 3  All
