November 23, 2024, 01:30:33 pm *
Pages: 1 [2] 3  All
Author Topic: "the back" of the CD is shown  (Read 39253 times)
Ava12
Headphone Audiophile
« Reply #15 on: February 19, 2009, 04:04:26 pm »
Yes. But it was my intention to show it as vague as right now.
Of course there is the option to show it in full (so no transparency) so you can just read the tracks from there (they will be there in 99% of cases), but indicating the active track is a tad too difficult. Happy And as I found, it is somehow informative to show the relative position, which doesn't work with a track name at the bottom + track number ("or a 4 out of 12").
You're right, I agree.
« Reply #16 on: February 20, 2009, 03:29:17 am »
Btw, a next version will show the real back when a back.jpg is present. secret
When you right click on a picture is there a way to rename it to back.jpg? like there is for folder.jpg... that could come in handy since I haven't named anything else but the folder.jpg pics.
I like the second pic of font style; but I'm not worried about seeing it from a distance.
« Reply #17 on: February 20, 2009, 07:52:27 am »
Right Dave. From far or nearby, that all doesn't matter much. But what about a couple of glasses ?
oops
hehe
« Reply #18 on: February 22, 2009, 07:13:23 pm »
Whether you like it or not, below two pictures have one main difference : the color of that small area at the bottom in the middle.
What would that be for ?
teasing
Ava12
« Reply #19 on: February 23, 2009, 12:39:29 am »
First, that looks really good Peter!
To your question, maybe Q1? scratching
Or total playback time for the CD? scratching2
« Reply #20 on: February 23, 2009, 03:31:41 am »
Volume setting? Not that important though...directory info?  None of these data being updated affect SQ, right? hehe  Going to jump to X on your next version,,, I promise.
« Reply #21 on: February 23, 2009, 09:31:46 am »
smirk You're on the wrong track. That area stays as you see it. Nothing to be in there. Only the color can change (as you see it). smirk
« Reply #22 on: February 23, 2009, 10:37:59 am »
After mulling over this for a day I reckon it's one of several possible indicators.
First choice is an indicator of how advanced into the track you are positioned. You start off with a white square and it gets darker the further in you progress until it shows black at the end.
Second idea is that the two different colours represented whether you were in attended or unattended mode, but I kinda figured you should know that anyway!
Another idea is it indicates the level of transparency for the "back" of the CD when not using actual covertart. Since these pictures both show covertart in use it's difficult to tell on this one.
Could also be font colour for when the "back" is in use.
Am I getting warmer huh Peter ??
« Reply #23 on: February 23, 2009, 12:34:06 pm »
Realtime Q adjustment?
Realtime adjustment for preset of different Q settings?
Wake from unattended to attended?
Rip function?
« Reply #24 on: February 23, 2009, 01:04:26 pm »
Because there's absolutely no analogy between that area changing color on one side, and what you suggest on the other, BUT you quite well feel what it should be about ...
« Reply #25 on: June 01, 2009, 10:38:03 am »
The fontsize could be a lot smaller and starting one line higher.
Make the font and - size selectable i.e. 6 - 10
make the "Back of the CD" optional
I still hope to get a 'Dynamic' Back for the 8" LCD screen to see all the tracks. (I know there is a limit)
Options:
show back
Font (e.g. Verdana) & size (disabled when back is not selected)
Colour of active track (disabled when ...)
« Reply #26 on: August 09, 2009, 02:17:12 pm »
For the upcoming version.
No dynamic fonts, but Verdana has been applied allright.
Notice that the first shown album has no back.jpg, while the second has. Still all the combinations are possible.
« Reply #27 on: August 10, 2009, 12:14:05 am »
Why the font change? I got used to the times.
BTW, in attended mode with taskbar autohide everything is exactly as I want Happy
Sometimes I prefer your back with track list (more visible than some albums back).
Does this message mean that now i can choose whether to display the back.jpg picture?
« Reply #28 on: August 13, 2009, 12:08:19 am »
Great job. Can you add maximum tracks, so I can see from a distance how far to go. See attachment
« Reply #29 on: August 13, 2009, 12:11:56 am »
Uhm ... Johan, are you *that* quick ? I only poored a whiskey in between uploading and your findings ... ?
Pages: 1 [2] 3  All
