November 23, 2024, 06:59:09 pm *
Author Topic: Argument OutOfRange Exception error in version 09v+x  (Read 21446 times)
« Reply #15 on: February 16, 2009, 03:09:24 am »
Thank you Johan.
I will look at it tomorrow, but it looks like that "IM" as the internally interpreted title of the album (2007 - IM)- and its 2 characters only, is doing it.
LydMekk
« Reply #16 on: February 16, 2009, 03:17:42 am »
Got the same error in X2. Just started the program and had a single wav in the playlist from before. Didn't get so far as to start playback, just started XX. Then the out of exception message cropped up with an OK. The player works normally afterwards.
« Reply #17 on: February 16, 2009, 06:08:15 pm »
Hi Johan,
I am fairly sure this particular error is solved in the 0.9x-2a from a few posts back. I still can't see what was wrong though, because I needed the Played.dat (not the !Played.plxx you sent). Played.dat is probably hidden in your XX folder.
But I think : never mind, because this error isn't there anymore.
Now I don't know what it means for the errors following this error. If all is right they are not there anymore as well.
« Reply #18 on: February 17, 2009, 12:08:55 am »
Indeed i have test Bugge Wesseltoft and Bobo Stenson. Both are played without the Argument OutOfRange Exception error (so far). Congratulations! You did solved something, but what caused it?
    .....because I needed the Played.dat (not the !Played.plxx you sent). Played.dat is probably hidden in your XX folder.
Can't find Played.dat in the XX directory.
I have seen one new error. When i start XX again during unattended playback and i change something in the settings, i get a "Reorganize Proxy" message.
Music starts playing again and when i accept the message i am back in unattended mode.
« Reply #19 on: February 17, 2009, 05:58:29 am »
Hey, great that it is solved. The XXDat0001.dat error is just a new error. I have it too and I will solve it (0.9x-2a is just a test version).
And never mind the Played.dat. We don't need it anymore.
But it is only there when you are playing.
Well, thank for your troubles Johan.
