November 23, 2024, 06:21:48 pm *
Author Topic: Error loading MP3 albums from Library cover art  (Read 6111 times)
« on: February 05, 2009, 06:10:03 pm »
G'day Peter,
I think i've found a bug that seems to have gone unnoticed for quite a few versions now.
When attempting to load a full album encoded in MP3 by double clicking on the album cover art in the centre pane, a warning window titled "Explode Cue File" pops up, with the following text inside ..
"Index and length must refer to a location within the string.
 Parameter name: length"
There is an OK button to press, and when pressed this message reoccurs for what seems to be related to the number of tracks in the album. At the end of pressing the "OK" button however many times it takes, there are NO entries in the Playlist.
I should note that I NEVER use cue files.
If I right-click on the album art and chose the "Load Individual Tracks in Playlist Area" option, I can then populate the Playlist using that method.
This bug is NOT evident in version 0.9w-6, but is in at least 0.9w-7, 0.9w-8, 0.9w-9b and 0.9x-1 ( which I still have installed in separate folders on my PC).
If you can't reproduce this bug yourself I will generate some log files for you.
Cheers, and sorry for the delay in reporting this .. I haven't been listening to many of my MP3 of late!
« Reply #1 on: February 05, 2009, 07:26:10 pm »
Hi there Russ, thanks. It was just mentioned yesterday here : http://www.phasure.com/index.php?topic=726.0 (first post #4).
It has already been solved and it will be available in the next version.
« Reply #2 on: February 06, 2009, 04:17:25 am »
ah .. yes .. now I see it. My understanding of the dutch language is somewhat limited and the wording of the error message failed to register with me.
Happy to report that 0.9x-1a had cured my problem  Happy
