November 23, 2024, 01:44:40 pm *
Pages: 1 2 3 [4]  All
Author Topic: Errors X1  (Read 51890 times)
« Reply #45 on: February 11, 2009, 10:29:27 pm »
Yep, already after track 3 it goes wrong. Music keeps on playing, but the cursor doesn't move, and in the mean time "Engine #3 did not start within the expected time".
I have enough data now ...
« Reply #46 on: February 11, 2009, 10:59:02 pm »
... but might you bump into something which lets repeat itself in shorther than 16 minutes, I'd be VERY happy. You'll understand that ...
« Reply #47 on: February 12, 2009, 07:40:19 am »
Also a strange thing lately is that showing the albums for the first time in xx after start up and put in the root in the settings tab is that the album area is turning white. ( no albums) Than i have to restart and than all is ok.
I've noticed this minor issue myself for quite a few versions now. Guess it's something Peter will want to look at when the killer bugs have been eradicated. Never occurs again though after the first restart.
In the mean time, Russ, is that Attened or Unattended with you ?
the "white screen" bug happens regardless of the setting of attended/unattended.
I've tried various combinations of settings and I can reproduce the bug simply by deleting the LibraryData.txt file from the working directory.
If I choose the Library tab, and then click on any entry in the lefthand gallery list, the folder art will appear in the middle panel as expected but will immediately be replaced with a whitescreen. Choosing another entry from the left panel will not change the middle panel. It will remain white.
If I close down XXHE and restart everything behaves itself as normal. It is only the initial running of XXHE when LibraryData.txt has not been created yet that this bug is evident.
Should be easy to squash this bug Happy
« Reply #48 on: February 12, 2009, 08:44:42 am »
Aha !
As usual and often Russ, Thank you ver much !
« Reply #49 on: February 13, 2009, 09:29:37 pm »
Solved in the next version. heat
And as always ... thanks for your time on nailing things down. yes
« Reply #50 on: February 16, 2009, 06:20:29 am »
hehe
sorry, I've had the whitescreen bug after a new install too, but goes away after the next startup, so I just haven't cared... sorry I don't report these things.
« Reply #51 on: February 16, 2009, 08:24:51 am »
But it is okay to do it anyway. Happy
Btw, this is solved in the next version.
« Reply #52 on: February 17, 2009, 06:16:36 pm »
......the "white screen" bug happens ...........
Sometimes after a "clear' command and a switch to the library area it takes a lot of time to show the library information. I have a black screen for 20 seconds.
« Reply #53 on: February 17, 2009, 06:53:55 pm »
Without clicking Search ?
« Reply #54 on: February 17, 2009, 06:58:58 pm »
Yes!
« Reply #55 on: February 17, 2009, 08:01:35 pm »
Can't it be so that at such a moment the Library Area contains albums from one of your music disks (like I:\) instead of from the Gallery ?
In that case the disk may need to spin up ...
« Reply #56 on: February 17, 2009, 08:33:11 pm »
No, the library is connected to the Gallery.
Select an album from the Library area
the traks are shown in the playlist-tab
Quits XX via the <OFF>-button
Start XX
Select the playlist area
Clear the playlist via <CLEAR>-button
Switch to the Library-tab
at the moment it takes 5 seconds
When you do this without quiting XX, it takes 1 sec to show the albums in the Library area.
