November 23, 2024, 03:43:32 pm *
Pages: 1 2 [3] 4  All
Author Topic: Errors X1  (Read 51906 times)
« Reply #30 on: February 06, 2009, 06:16:16 pm »
Ok, I think I found it. Please try below zip. It only contains XXHighEnd.exe (0.9x-1b), so copy it over 0.9x-1.
If you're at it anyway, look for new strange things during the first startup as well. Happy
If it works, thank Russ for his valuable hint.
Edit : Anyone using this, should also use the ChangeWP.zip underneath it.
* XXHighEnd-09-x1b.zip (464.65 KB - downloaded 550 times.)
* ChangeWP.zip (9.96 KB - downloaded 564 times.)
« Last Edit: February 07, 2009, 09:58:31 am by PeterSt » Logged
« Reply #31 on: February 06, 2009, 09:15:05 pm »
It's better as you see, but the slider does not go to the end but ends 1 cm before end. (than offcourse goes to the beginning). Music play's fine. As you see first start results in below error''s
Pic 1b3 apears 3 time's where it normaly apears only 1 time. The upper two before pic3...
EDIT: put in pic version 9b.....
« Reply #32 on: February 07, 2009, 09:54:33 am »
After a night of sleep I now realize that I changed ChangeWP in order to avoid that error (with the "X" and all). So that will be okay.
About the cursor stopping 1cm before the end, that is intentional, and always was like that.
I guess this problem has been solved now. Thanks Gerard.
« Reply #33 on: February 07, 2009, 10:00:44 am »
Btw Gerard, what is that XX.dat I see everywhere in your pictures ? Or is that from a rather old XX version maybe ?
« Reply #34 on: February 07, 2009, 10:08:46 am »
Ok super!!!
I don't know what it is.... Can i delete all of them?
« Reply #35 on: February 07, 2009, 10:14:48 am »
have another question. As you can see from both pic's the above pic from dianna shows two stripes from the time balk next to each other. The pic from 9b has those verdeeld over the whole area... But if that's ok with you it's ok with me..
« Reply #36 on: February 07, 2009, 11:41:19 am »
Yes.
Those stripes have a different spread at the two pictures anyway. The first implies 3.5 minutes and the second 3.0 minutes. The second implies that you indeed did something with track 1 lastly, and the first implies track 6.
This is something I don't have under control 100%, and only when the track is actually playing Attendedly, it should fit that track playing. One stripe is 10 seconds.
To understand better about my "not under control", play a track Attendedly, then click on another track and do nothing more. Now the scale is wrong, but the cursor keeps on running. It may turn out in some anomaly when the cursor reaches the end ...
« Reply #37 on: February 09, 2009, 11:16:58 am »
Like everybody I had a lot of errors, to much to see any systematic causes, but you really solved them!
Only one is left for me:
6: Sometimes music just stops playing.
This happens almost with all the music I play and I think it happens after about 1 hour of playing a (long) album.
When I only replay the song where it happens everything is OK. If I restart the complete album it happens at the same song again.
I get the messages 'Engine # did not start within..' then: 'no track given' and then 'no track data received'.
After clicking the messages I can restart with the next song.
(X1 and X2 the same)
« Reply #38 on: February 09, 2009, 11:27:18 am »
Hmm ... that seems strange.
Can you mention the album you are experiencing this with ? and at which tracknumber it stops ?
Furthermore, please mention *all* of your settings at which this happens !
And you wouldn't have a log file of it ? nea
If not, don't make it especially for this (takes too much of your time) but in that case I hope I have that album ...
« Reply #39 on: February 09, 2009, 12:01:14 pm »
One album is creedence clearwater revival, Chronicle, the 20 greatest hits, where it happens at song number 17, 'I heard it through the grapevine'. It is flac.
There were some more albums but I'm not sure which ones so I'll try to find some more.
My settings are:
- No processor appointment
- below normal
- high,
Dac = 24/192
32 bits
disable crack detect
width 320
split file 100
tooltips on
unattended
showdata
Volume 0
Q1 14
Q2345 15
Ï'll try to see if a regular WAV is having this problem too.
Yes, Cassandra Wilson Blue Light as Wav after song 4 'Children of the Night'
'No track given'   'No track data received' 'Enine three did not start'.
I'll try to see if I can repeat it.
Yes repeatable.
Added two logfiles.
I removed some garbage from the musidirectory and play with 300 in stead of 100, no problems yet. Could this be important?
No success, still the same problem...
* XX-20090209-125314.log (13.04 KB - downloaded 548 times.)
* X3-20090209-125405.log (3 KB - downloaded 539 times.)
« Last Edit: February 10, 2009, 10:19:51 am by GerardA » Logged
« Reply #40 on: February 09, 2009, 04:20:00 pm »
Also a strange thing lately is that showing the albums for the first time in xx after start up and put in the root in the settings tab is that the album area is turning white. ( no albums) Than i have to restart and than all is ok.
I've noticed this minor issue myself for quite a few versions now. Guess it's something Peter will want to look at when the killer bugs have been eradicated. Never occurs again though after the first restart.
« Reply #41 on: February 11, 2009, 12:13:32 pm »
Hi Gerad(A),
In your last post you said you played Unattended. You logfile shows otherwise.
Can you confirm (either) ?
In the mean time, Russ, is that Attened or Unattended with you ?
Thank you both,
« Reply #42 on: February 11, 2009, 12:19:00 pm »
Sorry, I play attended now to try all the settings.
So the logfile is right.
« Reply #43 on: February 11, 2009, 09:45:13 pm »
I just tried that album - volume one - and while all went right I then discovered this was a cue file version.
Might you have another example, please let me know.
(I have volume 2 in a normal version)
In the mean time ... your log file indeed shows things go wrong, but right now I don't know what to make of it really. It is a start though.
« Reply #44 on: February 11, 2009, 10:02:54 pm »
Uhmm ... I only now see (must have been blind before) that your logfile is about Cassandra Wilson. Well, I have that one in WAV as well.
Let's try again ...  Happy
