November 23, 2024, 01:38:36 pm *
Pages: 1 [2] 3 4  All
Author Topic: Errors X1  (Read 51889 times)
« Reply #15 on: February 04, 2009, 08:28:38 pm »
Your numbers 3 and 4 have been solved and will be in the next version.
Config File??? Were to look...
« Reply #16 on: February 04, 2009, 08:51:26 pm »
I have done what you asked. But that was not the trick.  unhappy
I deleted the config of today 5 feb. there was only 1.
EDIT: Have given it another try. But Nope....
Also a strange thing lately is that showing the albums for the first time in xx after start up and put in the root in the settings tab is that the album area is turning white. ( no albums) Than i have to restart and than all is ok.
« Reply #17 on: February 04, 2009, 10:51:42 pm »
Help ...
Unzip the latest XX to again a new folder
Gerard, did you do that ? a NEW folder ?
« Reply #18 on: February 05, 2009, 08:50:10 am »
Help ...
Yes i did it 3 time's and every in it's own folder.
« Reply #19 on: February 05, 2009, 08:57:14 am »
This is impossible ... I mean, there is no way the screen can obtain those sizes by itself.
Do you indeed get the question right after the install "Your settings have been lost ... Restore old settings" ?
And do you answer No each time ?
« Reply #20 on: February 05, 2009, 09:32:21 am »
I alway's say no to restore settigs and put in the code manually.
 unhappy Happy
« Reply #21 on: February 05, 2009, 11:59:27 am »
At this moment I can only think of the "advise" to install XX on another PC (demo does not matter), so you may see yourself what the differences are, and that you maybe from there on can find what is the matter. But something really is wrong here ...
« Reply #22 on: February 05, 2009, 12:25:11 pm »
 unhappy I do not have one where i can do that.... And the music play's so i do not have a big problem with it....
« Reply #23 on: February 05, 2009, 07:43:27 pm »
Ok Gerard, if you have some energy left ... you could try the XXHighEnd.exe in here : AIF Support ?
Nothing in there has been explicitly changed for your problem, but it is another compile anyway, and supposed you have problems with some bits fallen over, this might help. Btw, the MP3s load normally in that version (0.9x-1a) as well.
« Last Edit: February 06, 2009, 07:32:07 am by PeterSt » Logged
« Reply #24 on: February 05, 2009, 08:01:48 pm »
Well, if you want, you can try it with the below zip. This is XXHighEnd.exe only; just copy it over the current 09.x-1 install (not over an older one !).
Please let me know.
Have to wright it again....  unhappy
There is no difference.... I like to show you that with the same track length (+) but with different cd's the hidden time is different. Also the root right at the bottom is different.
 scratching scratching
« Reply #25 on: February 05, 2009, 08:06:10 pm »
scare
« Reply #26 on: February 05, 2009, 08:33:23 pm »
Can you check in c:\users (all subfolders) whether there are any spurs if XXHighEnd.exe, Unicodetrack*.wav, *.wav ?
Remember, set Show Hidden folders and all to Yes (if you see the c:\users it's allright I guess).
Edit : See above Unicodetrack*.wav (which I put differently earlier).
« Reply #27 on: February 05, 2009, 08:41:23 pm »
Nope noting like anything you showed.... Or anything like that.....
« Reply #28 on: February 06, 2009, 04:39:32 am »
it may be unrelated to Gerard's sliderbar problem, but when I started 0.9x-1 for the first time ( and subsequently 0.9x-1a ), XXHE's GUI window appeared to be outside the normal viewing area of the desktop. Likely co-ordinates were in the negative. If I used the "Maximise" function from with the taskbar entry for it, XXHE would appear and fill the screen as expected. If I then tried the "Restore down" button ( top right hand corner ) it would disappear again.
I had to use the "move" function to bring it onto my desktop, which I should add hasn't changed in definition since its initial build. ( 1280 x 800 pixels )
Once I had the window visible on my desktop everything behaved normally.
« Reply #29 on: February 06, 2009, 07:16:41 am »
Aha ... scratching you are right. In that area something *did* change ... scratching
