November 23, 2024, 12:58:56 pm *
Pages: [1] 2 3 4  All
Author Topic: Errors X1  (Read 51879 times)
« on: February 04, 2009, 09:39:21 am »
Hey Peter,
I am sorry but i receive al lot of errors with x1.
1: First is the sliderbar. The slider moves forward at the end but i cannot see it anymore. looks like the screen has to expand but thats not possible here.
2: When i like to stop xx and press stop and than off the error below shows up. (x1.1)
3: When i like to press clear i have to press stop first. That was not how it was before. When i like to press clear during playback than this error apears. (x1.2)
4: When i like to load in a mp3 than this error apears with every track. When i load in by explorer than no problem. (x1.3)
5: During playback and going to the next track sometimes this error apears but music keeps on playing. (x1.4)
6: Sometimes music just stops playing.
Oh ja all is attended and i have not installed the hotkey program yet.
And there are some more wich i will ad later...
Sorry  unhappy
Grtz Gerard....
« Reply #1 on: February 04, 2009, 09:57:27 am »
Wow ... Cry
For now about your #2 ... Can it be that only now you ticked "Copy to XX-Drive by standard" (similar) for the first time ? As you can see this is some rights problem ...
And about #1, can you tell me the sequence of dragging stuff when this starts to happen ?
The other things I should be able to copy myself.
Peter oops
leifchristensen
« Reply #2 on: February 04, 2009, 10:06:46 am »
maybe your R&D department  Wink needs a holiday scratching
best
Leif"stay happy with 9b" Christensen
Norway
« Reply #3 on: February 04, 2009, 10:07:56 am »
best
Norway
prankster wacko
« Reply #4 on: February 04, 2009, 10:10:13 am »
Wow ... Cry
Peter oops
You have questions about 2: and 1: ?? See above... I understand your first question #2 but not #1.
« Reply #5 on: February 04, 2009, 10:24:19 am »
About #1 :
The screen you showed does not have the default size (of the panes) right after the first startup. So, you dragged it to that size, but since you must have dragged the panes wider as well, I just want to now the sequence of your dragging things, and exactly when the slider starts to be outside the boundaries of the form. With me this doesn't happen ... not by itself ...
« Reply #6 on: February 04, 2009, 10:36:00 am »
Wow ... Cry
Peter oops
About #1 i cannot get it bigger.... Will try other versions... And below are my settings...
« Reply #7 on: February 04, 2009, 10:42:05 am »
9b is ok only x1 seems to have this... It's about the last +- 8 sec of a track... Tried to get it bigger but can't.
« Reply #8 on: February 04, 2009, 10:44:19 am »
If you drag the right side to the LEFT (so, make it smaller) doesn't the slider reset to such a size that it fits again ?
« Reply #9 on: February 04, 2009, 10:47:52 am »
No it stay's the same only smaller....
« Reply #10 on: February 04, 2009, 05:15:21 pm »
Gerard, please help me.
Unzip the latest XX to again a new folder, ans start XX. Answer No to "restore settings". Don't touch anything for dragging borders or anything. Don't even move the form. Now :
Is it wrong already with that slider ? please send a screencopy of that.
Is it okay ? please start dragging things, possibly as you did before (if you can remember), write down what you do, and watch closely for the slider getting wrong. When that happens, let me know what you did !
... Chances are high (I hope) that you will not be able to reproduce it.
If all stays right, next try to let the message "Engine 3 did not start ..." appear again. Probably it is unrelated to the slider thing, but maybe it just is related.
I don't get this ... (both things) ...
« Reply #11 on: February 04, 2009, 07:07:42 pm »
Your numbers 3 and 4 have been solved and will be in the next version.
« Reply #12 on: February 04, 2009, 08:13:15 pm »
I downloaded x1 and did the same i alway's do and what you asked for. No need to activate. As you see the screen is not correct.
I will try to provoce the engine 3 did not start....
« Reply #13 on: February 04, 2009, 08:14:35 pm »
Also Gerard, make sure that your install is correct. I man, don't know how many albums I must run to make that "Engine 3 did not start ..." happen, but I give up on it. Besides that, too much time was spend on it, and I concider that solved. IOW, make sure you don't run with an old XXEngine3 version !
And check your rights. Your #2 error sure indicates something is wrong there.
scratching
When the attachment is there ...  Happy (which it is not yet)
« Reply #14 on: February 04, 2009, 08:19:56 pm »
Ok, in that case delete your latest config file. But ... where the heck has that topic gone ... dntknw
Edit : here : How to delete a misbehaving ConfigFile
