April 06, 2025, 05:23:38 pm *
Pages: 1 [2] 3 4  All
Author Topic: AutoHotkey Install  (Read 85052 times)
« Reply #15 on: February 06, 2009, 08:42:26 pm »
OK, I did as you suggested and all appears to be running fine as long as XX is run as administrator. I will play most of today and watch for errors.
It does affect how my machine runs though so (forgive my ignorance here) what is UAC and how do I shut it off? I seem to be getting a lot of Host Process Stopped Working errors when XX is run as Administrator.
UAC = User Account Control. I think this is mentioned in the topic I referred to ? Vista Users ... prepare yourselves ... This is about the screencopies below the CPU graph in there. Of course this is dutch (who doesn't know dutch Happy) but I figured it was clear. Maybe not scratching
That just that incurs for those "stopped working" errors I never knew, and you just as well can be right on this one. But in that case ... one first prize for you. biglol
Anyway that is a virtue. Believe it or not. The more services shutting down themselves the more this is needed for the best SQ. Really !
But I will look into the merits of this (just in case you are right hahaha). But don't be bothered by it. Unless ... unless you are disturbed by a Windows 3.11 look which it in the end may come down to, and you want to use the PC for other things as well.
Thank you Mike, appreciate it.
« Reply #16 on: February 06, 2009, 09:39:19 pm »
I never new that i alway's have to do it again. (after a new version)  Meaning run xx as administrator. Alway's thougt that one time was enough....
 unhappy
« Reply #17 on: February 07, 2009, 11:42:49 am »
Not of you change the icon.
Ava12
Headphone Audiophile
« Reply #18 on: February 11, 2009, 10:03:06 pm »
just now I thought wouldn't it be nice to have a hotkey for next album in the playlist (e.g. ALT+A).
Because sometimes it's really annoying to go attended and switch to the next album in the playlist and press play.
I know there are many ways of playing music and I prefer loading lots of albums in the playlist and then just press ALT+N till I hit the next album. But since every Hotkey takes about 2 secs it's really annoying.
Wouldn't that be pretty simple? If not and you feel it causes just confusion with all the hotkeys just let it the way it is. Wink
Greetz Ava
« Reply #19 on: February 11, 2009, 10:35:02 pm »
Hi Ava. Good idea, very feaseable, and furthermore already in my mind. It sure will be in there.
As I see my self there are more annoying things. Pumping up the volume by more than 2 steps is one of them, and the 1-2 seonds quietness is another. At least the latter can be solved. Not so easy, but it can.
But first I am still struggeling with the 0.9w changes, because the new method of memory management still gives bugs here and there. I really first need to fix those (not because I can't do two things at one time, but because both will relate to eachother).
Keep on comin with the ideas !
Ava12
« Reply #20 on: February 11, 2009, 11:21:45 pm »
Thank YOU!!! Didn't wanted to rush to you with the tiny pause of changing the volume/everything else, but in the back of my head.
Wow and with changing volume with more than 2 steps, ok could have thought about this (to me:why didn't I?) but since you can read minds, or are simply a genius at what you do for XX, can't decide which one it is, tend to the latter, nothing is lost. Happy
Ok when I can think of some other things you'll be the first to know, well second but...
« Reply #21 on: February 12, 2009, 12:00:10 am »
... But do you perhaps really have some remote control going ? if so, please let me know how and what. I have a hard time on that one ...
Ava12
« Reply #22 on: February 12, 2009, 12:08:37 am »
Sadly no, I tried but my vista for some kind can't recorgnize my built in remote control. Or it is really damaged, I will open my laptop tomorrow. And I don't know if WinLIRC will find it or work with it, I will have to check the chip set and the connection to the mainboard.
Would be nice since everything is built in already and I've got a small remote control which worked with XP and PowerDVD I think.
I'll try tomorrow
« Reply #23 on: February 12, 2009, 12:42:22 am »
I have done some testing with IR2Keyboard (freeware) remote control translator. You can find it here http://www.fast351.com/hometheater/htpc/
Via the remote-controle i started XX two times......!?!?!?!!! And when i minimize IR2Keyboard id won't accept commands anymore.
From the developer:
The utility connects to the IRTrans server, and takes the incoming infrared remote control presses and and translates them into keyboard commands. IR2Keyboard can translate any remote control command and target it to any application, using any keyboard press!
« Reply #24 on: February 12, 2009, 08:50:33 am »
Well, these things are my experience as well. All these things seem to be very wacky. I will try I2RKeyboard as well.
Bu I hope someone just has the good experience and can share ...
Ava12
« Reply #25 on: February 12, 2009, 01:33:33 pm »
Geeez, can't get nowhere with Girder, wrong usb-ir device. Sad
Ava12
« Reply #26 on: February 12, 2009, 06:06:29 pm »
Y E S ! ! ! ! yahoo I did it! I'm so proud!
I've got a remote for my XX
My system consist of a Sony Ericsson Cell phone (but almost any would do) with Phone Remote Control 3.0, the pendant is installed on my laptop and I've got a simple USB Bluetooth stick which runs under BlueSoleil.
Now I have makros on my cell, so when I click 1 XX starts, when I click 2 on the cell the tracks starts to play.
3 is volume up, 4 is volume down etc
Ava12
« Reply #27 on: February 12, 2009, 06:23:01 pm »
Now ok, too early.
It doesn't work flawlessly. For example it does sometimes work only in attended mode, and sometimes it takes ages to execute the makro. But it works.
And a major flaw is that this the demo I'm using, and so after 5 or so commands the program on the cell shuts down and I have to reconnect, which doesn't take that long, but you wouldn't want this to happen all the time.
« Reply #28 on: February 12, 2009, 06:35:13 pm »
Ahaaaaaa ...
So I should get rid of my serial IR receptor, the via-the-TV-card IR receptor and the USB IR receptor, and get out that USB BlueTooth receptor I bought over a year ago, and ask back the cellphone I gave to my wife because I thought it is a clumsey thing.
hehe
Be careful this isn't somehow caused by AutoHotkey. I don't think so, but keep it in mind !
I just asked for the phone, a Sony Ericson K850i. It contains remote control functions by standard. WMP etc. preinstalled. Hmm ... Let's get that BlueTooth receptor ...
« Reply #29 on: February 12, 2009, 07:02:27 pm »
Well, already right now I want to use that phose as a baseball. I sure didn't give it away for nothing.
Maybe later.
On some relevant other note ...
With this AutoHotky thing I wanted to create something very general that everybody would be able to use. In the mean time it should give provisions to more extensive stuff like the Pronto TSU9600 I own (it does IR and WiFi). But all somes down to the receptor in/on the PC, and the software behind that which must be able to remap e.g. IR commands to
- the hotkeys as defined by me in the XX.ahk file
or
- the passed through (IR) commands (could be "volume_up") and define them in the XX.ahk file (like "volume_up:" -> not :: !)
Note that the more official way would be "IP commands" but this requires even more knowledge from the user and a normal remote would be useless for that.
Page created in 0.023 seconds with 19 queries.
