April 17, 2025, 09:14:48 am *
Author Topic: problems saving settings  (Read 5605 times)
leifchristensen
« on: January 27, 2009, 09:49:36 am »
hello P
I have a friend Harald whom I often help by remotecontrolling his pc via www.logmein.com
When I replace old xx version on his vista ultimate laptop with a new one I have big problems saving all the settings and yesterday I simply had to delete the old version,load up the new one,undemo it and do the settings
Any clue?
Should there maybe be a "SAVE SETTINGS" button on the desktop of the XX ?
best
Leif
« Reply #1 on: January 27, 2009, 10:17:53 am »
No clue Leif. And not the experience either (I started a thread about this the other day).
But if you follow this How to delete a misbehaving ConfigFile and then mainly the part about just deleting such a Config file because of which XX again will start the question "Reload old settings" where you should answer NO at problems ... it will solve it most probably.
On a sidenote, this is standard Windows stuff, while I can do it explicitly myself just the same. In a next version the explicit thing will be in there. Seems a lot better (under control) to me.
