November 23, 2024, 12:09:36 pm *
Author Topic: Can't see Q sliders under  (Read 7412 times)
« on: January 25, 2009, 08:55:45 pm »
Under Qcontrol tab
I can't see the sliders.
I can see the headings Q1=14 (then about a half inch space) Q2=0 Q3=0 Q4=0 Q5=0 (Q2-Q5 all have the same small space)
but not the sliders... except
Q5 slider is way to the bottom right.
EDIT
Also, when I mouse over the blank areas of Qcontrol panel the Q settings of Q1 Q4 and Q5 show up as a tooltip... but I can't see the sliders... I've tried a couple different resolutions ...doesn't change.
fyi
native resolution is 1440*900 60hz
EDIT2
(side note) for as long as I can remember the "Processor Core Appointment Scheme" selection box cuts off the beginning of the selection (ie half of the S in "Scheme 3" doesn't show, and if I was to choose "No appointment" it shows up as pointment in the box)
« Reply #1 on: January 25, 2009, 09:54:38 pm »
Huh ? would you care to show pics of this ?
Also show a picture of the volume slider please. This one is even smaller.
Thanks.
« Reply #2 on: January 25, 2009, 10:45:56 pm »
Anyway ... I've made the sliders as large as they were before.
In original download a XXHighEnd-0.9-w9a.zip is obtained now for that.
Currently, the XXHighEnd-09-w9.zip in there contains the adjustment too (and shows as 0.9w-9a).
Edit : Above is not true anymore. See my next post below.
« Reply #3 on: January 25, 2009, 11:49:29 pm »
Here it is from W9
Will try W9a after lunch
« Reply #4 on: January 26, 2009, 12:19:56 am »
Ah, now I see ! This happens at resizing the middle pane.
Here is a full new version now : XXHighEnd Model 0.9w-9b (solves Q parameter dislocation)
Sorry for the inconveniency.
