April 19, 2025, 11:22:11 pm *
Author Topic: XXHighEnd Model 0.9w-9 (solves Attended bug + new Q Parameters)  (Read 7841 times)
« on: January 25, 2009, 07:51:46 pm »
  • If all is right the "No track given" (and more anomalies in this area) problem has been solved (this was an Attended Playback bug only).
    Note : One part of the "solution" was the removal of a back door solution which emerged a longer time ago against Engine3 running silent. It is not known whether this still can happen, but the backdoor solution of stopping and restarting XXEngine3 has been removed. This, because under the current conditions it might just abort a playing track (with sound). If now suddenly XXEngine3 runs slient where before it never did, please report. This can happen at Attended Playback only.
  • Again some improvements have been applied to switching between Attended and Unattended and changing settings and wanting to continue playback at the point playback was at either side (Attended/Unattended).
  • The Q1 slider has been moved to the QControl Area.
  • Besides Q1 now a Q2, Q3, Q4 and Q5 exist. See Q Parameter Settings.
    It may even be advised not to use these new parameters because of the sheer unlimited combinations of settings, and it is not even known whether they really influence.
  • The notch up/down volume buttons won't imply a restart of XXEngine3, which only happens at pressing Play after a volume change by means of the notch buttons.
    Note : It can't be determined whether this was already in 0.9w-8, but most probably not.
Edit : It has been reported that the sliders in the QControl Area are not visible and can not be manipulated.
Edit 2 : Removed the download zip below because of beforementioned bug. Please go to 0.9-w9b now.
