November 23, 2024, 12:12:09 pm *
Author Topic: 0.9w-8 won't launch at /64  (Read 15416 times)
Jack
« on: January 21, 2009, 10:13:37 pm »
Hi Peter
I have my own w8 problem, it won't launch. I immediately get the message "XXHighEnd has stopped working" Perhaps a 64bit thing? All previous versions work fine. It's a fresh install in it's own folder on the root of C: as usual.
Happy days
Jack
« Reply #1 on: January 22, 2009, 07:19:05 am »
Hmm ... can you try the 0.9w-8a from here : w-8 Sound problem.
I sure hope that that one goes.
« Reply #2 on: January 22, 2009, 09:19:49 am »
I've been running all versions since V (that includes the latest W8) on vista prem 64 bit.
Jack
« Reply #3 on: January 22, 2009, 10:58:40 am »
Hello
Just tried 8a. Same result, same message!
Jack
« Reply #4 on: January 22, 2009, 12:16:11 pm »
Can you make a copy of the contents of that message ? Note you can open it for details.
Most probably you can't suffice with one screenshort, because there's a scrollbar.
Btw, isn't there another message in between (like save your old settings, blahblah) ?
Jack
« Reply #5 on: January 22, 2009, 12:37:45 pm »
Hi Peter
All I get is one message, no more clues I'm afraid!
Jack
« Reply #6 on: January 22, 2009, 12:54:34 pm »
Prrrrt. Well, Windows will inform you when a solution is available, it says. swoonteasingswoon
« Reply #7 on: January 22, 2009, 01:01:44 pm »
If you popin an XXHighEnd.exe in that folder (!) from a version you know it worked ...
It then may work again, but next you put back the .exe from 0.9w-8 (again in the same folder). Maybe that helps ?
I'm rather clueless, but it should be related to the "saved settings". You can explicitly throw those out too, but I must look up where they sit (somewhere under c:\users\) which is posted on the forum somewhere.
Jack
« Reply #8 on: January 22, 2009, 01:40:07 pm »
Hi
Tried that yesterday, no go, I'll stick with w7 & wait for next version to see what happens then.
No one's going to die in the meantime!
Jack
beto
« Reply #9 on: January 22, 2009, 04:16:46 pm »
w8 runs and sounds great on my Vista x64 and Windows 7 x64, its definitely your setup not w8.
« Reply #10 on: January 22, 2009, 06:39:51 pm »
Jack, I have put something together for you. Please try it : How to delete a misbehaving ConfigFile.
Jack
« Reply #11 on: January 22, 2009, 09:13:05 pm »
Hi Peter
I have found the problem, it was my fault & I'm sorry to have wasted your time (grovel. grovel).
When I first unpacked v8 it spread itself all over my C drive, thinking it hadn't worked I did it again. This time, as usual, it unpacked into it's own folder on the root of C: as I mentioned. I was just going to try your solution when I noticed XXHE files all over the place, so I deleted them. Having done so it now runs as it should. So, for whatever reason these random files stopped it from running!?
Sorry, what did you say, I'm a what?
Happy days
Jack
« Reply #12 on: January 22, 2009, 09:55:59 pm »
No Jack, I'm just glad you could solve it.
But I didn't quite get what happened. grazy
« Reply #13 on: January 23, 2009, 04:58:11 am »
Sounds like he unzipped W8 just onto the C:/ drive; not into a folder.  He then deleted all those XXHE files and unzipped W8 into its own folder... and now things work.
Jack
« Reply #14 on: January 23, 2009, 11:50:37 am »
Hi SeVeReD
That is exactly what happened, W8 didn't like being in 2 locations on the same drive, I guess.
But all is well now!
Back to the music!
Happy Jack
