November 27, 2024, 12:52:20 pm *
Author Topic: Screen/Video crash with 0.9-w6  (Read 24074 times)
0 Members and 13 Guests are viewing this topic.
bgjohan
« Reply #15 on: January 28, 2009, 02:27:17 am »
1. Unattended - thanks for the clarification, I thought Unattended only meant that the program moved from song to next song in the playlist w/out the need for manual instruction. When running in Unattended mode, the whole program disappeared, i.e. was not available from the bottom task bar in Vista 64.
Running in Attended mode, I can easily minimize the program to the bottom task bar, call the program up again and make changes, Start playing again w/out issues and even have the progressing bar working. Only remaining sign of any problem is that I seem to have lost some of the progression bar markers.
2. Album covers as jpg pictures; the loading on the right hand only occurs when the album does not have a picture associated with it and XXHIGHEND seems to display all available album pictures (jpg) available. I have attached a print screen from an albun with jpg attached. Picture appears a bit small, but is otherwise functioning normally.
3. Problem of screen overlay at startup - nothing much to worry about, it fixes itself if I minimize and re-open the program in full screen.
4. Quality setting; I have played wih setting at high Quality (24) assuming that my PC (dual processors, 6GB of RAM) has enough power to handle such a setting. Thankful for your comments on this, if you disagree or would like to suggest other Quality setting.
* 09-w9b jan 28 2009.doc (291.5 KB - downloaded 566 times.)
bgjohan
« Reply #16 on: January 28, 2009, 02:37:05 am »
Quality setting:
In my previous post, I commented on setting to 24. However looking back at the program I see that it was NOT Quality set to 24, rather Q1=parameter 24 in 09-w8.
However, in 09-w09b the Q1 Parameter setting is missing - this is what I was referring to as Quality setting missing - sorry my mistake (causing confusion).
Thus my question: Has Q1 slider been eliminated in 09-w09b, or am I in fact missing something?
Bjorn
« Reply #17 on: January 28, 2009, 05:36:18 am »
Quality setting:
Bjorn
The new Q settings can be found under their own tab now called QControl.
It will be a long time until I post any feelings about them, but
4,8,1,0,2
Then again, those numbers will change faster than two shakes of a lambs tail.
« Reply #18 on: January 28, 2009, 08:51:20 am »
I will move the Q1 slider back to where it was ...
« Reply #19 on: January 29, 2009, 03:32:41 am »
I really like having all the Qs under the tab QControl.  I think there was only confusion because experienced XXHE people were looking for it in the usual place.  New users, who would naturally explore XXHE, will find it easily under the QControl tab, and Vets of XXHE just need to have their attention directed to it.  I for one, hope you don't move it back; you may find it gives you some layout control later on.
4,5,1,0,2
sounding very full and rich; i likea
Leo
« Reply #20 on: January 29, 2009, 07:30:53 am »
I agree with SeVeRed
Leo
« Reply #21 on: January 29, 2009, 09:17:54 am »
To me it somehow doesn't feel right. Q1 is just working and doing a kind of certain job. Now, newcomers don't know this. So what will happen ? they will slide Q1 along with the others. Q2-Q5 so far don't make much sense. Q1 does.
