April 05, 2025, 02:01:01 pm *
Author Topic: XXEngine3.exe  (Read 30381 times)
hal3101
« on: June 17, 2007, 08:47:59 pm »
Can't be startet in Model 0.8
Error code: The application has failed to start because ist side-by-side configuration is incorrect. Please see the application event log for more details.
The engine 2 is ok and fully functional.
TorH
Home build pc, Intel Dual core 4300 1.8 GHz , Vista Business, 2 GB RAM, one 500 GB harddisk, Q1 -3 with checked invert, appoint processor cores checked, Engine 3 checked, Double and upsamp NOT checked -> USB DDDAC -> TVC -> 300B -> Oris 200
« Reply #1 on: June 17, 2007, 08:54:59 pm »
Ok, so this is the same as the last time I could try it.
I know what this means, but hoped it wouldn't be there anymore.  unhappy
Btw, this is about a phenomenon I didn't know of before, and which keeps track of all consistent software versions. It (I now know) exists on XP just the same, but I never heard of it overthere. And oh, it makes your disk get full by many many gigabytes by full automation.  Happy
Let's get Google ...
« Reply #2 on: June 17, 2007, 09:03:21 pm »
I get the same error when I want to start XXHighEnd#3 directly from within the directory, selecting it from within XX (I thought that would be the way to choose between 1, 2 and 3?) then I do not get any error. It doesn't play though...only #1 and #2 are playing tracks.
« Reply #3 on: June 17, 2007, 09:11:11 pm »
Hmm ... Starting it from XX is the way to do it ...
(starting it directly is not possible, but should NOT give that error anyway -> it should just do nothing then).
« Reply #4 on: June 17, 2007, 09:14:34 pm »
http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=1712336&SiteID=1
If that's the solution ... yeah, I have that.
But this obviously should not necessary for you out there (so do NOT download that, evenif you're developing software -> away goes the testcase !).
Uhoohh
« Reply #5 on: June 17, 2007, 09:37:54 pm »
I could download it and install it on my Laptop just to see if XX#3 then works, I will then have at least 2 different Vista versions running trying to find the needed files to make it work on the other PC.
Or you should compile the needed files within XX or add an install.exe so that we only have the needed files at the proper place...
« Reply #6 on: June 17, 2007, 09:58:55 pm »
No Bert, this would be stupid. It must be solved anyway.
If needed, I'll even find the components needed from Visual Studio.
Thanks.
Jack
« Reply #7 on: June 17, 2007, 10:51:24 pm »
Hi Peter
Just to confirm exactly the same as Bert on my machine
Jack
« Reply #8 on: June 17, 2007, 11:35:09 pm »
Ok. First attempt at solving this.
Note I'm trying this as lean as possible, so maybe it needs more attempts.
Thanks again !
DO NOTE that the DLLs contained in the zip below should *NOT* be copied to the Windows directory, nor should they be registered.
This implies that XXHighEnd should not be installed in the Windows directory (or subdirectory therefrom). But you wouldn't do that anyway, would you ?  nea
Edit : Removed the zip (which was useless afterall).
« Last Edit: June 19, 2007, 11:45:50 am by PeterSt » Logged
hal3101
« Reply #9 on: June 17, 2007, 11:59:02 pm »
Error code is gone but there is no sound. Nothing else to report. Engine 2 is ok.
TorH
« Reply #10 on: June 18, 2007, 12:01:43 am »
Thanks ...
Can you verify by Taskmanager that XXEngine3.exe is running after you pressed Play (for a track) in XXHighEnd ?
Btw, do NOT use tracks with  diacretical marks ! ... because then you wouldn't have sound indeed (in the current version).
hal3101
« Reply #11 on: June 18, 2007, 12:04:54 am »
No it is not started.
« Reply #12 on: June 18, 2007, 12:11:15 am »
And do you have both these checkboxes ticked for your sounddevice ?
(I didn't mention that before ...)
(and is that device your Primary Device ?)
« Reply #13 on: June 18, 2007, 12:31:28 am »
Also I'd like to know this :
One of the files in the latest zip is this one : XXEngine3.exe.intermediate.manifest
If you delete that (but keep it somewhere else) ... does that change anything ?
Thanks again.
« Reply #14 on: June 18, 2007, 10:12:45 am »
Nothing changed here, "same" SideBySide error...the logbook shows a different error in the detailed report though.
Same error message too when I directly want to open XX#3.exe
Best would be if you would pickup my Laptop and see for yourself what is changing instead of me making screendumps over and over again...
