November 23, 2024, 03:21:52 pm *
Author Topic: 19.5 volume setting  (Read 10471 times)
« on: January 18, 2009, 07:32:50 pm »
from W8 release notes...
"It was found that one of the new digital volume steps (-19.5dB) attenuated much more than intended. Solved."
Not fixed here.  19.5 is very far down in vol compared to 18 or 21.  Found this out with Via Audio album, and checked with a Verve album and Yoyo Ma - Made in America...  same results; greatly reduced volume at 19.5 setting.
« Reply #1 on: January 18, 2009, 09:39:08 pm »
(removed the test from 4 mins ago in this post)
From what date/time is your XXEngine3.exe ?
« Reply #2 on: January 19, 2009, 01:49:08 am »
modified
Thursday January 15, 2009 5:46:58 pm
(I was going back and forth listening between W7 and W8 a couple times... I don't suppose that could throw anything outta wack)
« Reply #3 on: January 19, 2009, 07:22:51 am »
Can you try below version of XXEngine3 ?
It shouldn't work either because I didn't change anything in that area. But the compilation date now 100% is after the date of 0.9w-8.
Btw, of course I rechecked the code, and that definitely has been corrected (on the date of 0.9w-8 ... I don't register times nea).
* XXEngine3.zip (55.35 KB - downloaded 547 times.)
« Reply #4 on: January 19, 2009, 09:07:07 am »
Just downloaded XXengine3.zip; It works, 19.5 is playing the correct level. ... dunno
« Reply #5 on: January 19, 2009, 10:44:21 am »
... dunno
Thank you Dave. I really don't know what happened at creating the Zip for 0.9-8w. I can hardly imagine that I created the Zip and then changed the code. But somehow I must have done that anyway ...
Leo
« Reply #6 on: January 19, 2009, 04:00:46 pm »
I also had the 19.5 db thing still there in W8. With this really new zip it is solved
Leo
ps
Is the Fidelio .exe for general use or just his special version of  w6 ?
« Reply #7 on: January 19, 2009, 05:04:54 pm »
Edit : Removed original text, which was actually in the wrong topic. Se here now : Re: w-8 problem
