November 23, 2024, 09:46:33 pm *
Author Topic: XXHighEnd Model 0.8 (with Engine #3)  (Read 9149 times)
« on: June 17, 2007, 07:07:26 pm »
Changes and notes :
  • Engine #3 is now included. Note that this is a rather "uncalibrated" version for soundquality.
  • XXHighEnd now gives a message when another Playback Device is chosen than the Primary Device for Engine #2 and Engine #3.
Additional Issues :
  • Currently when the player quits due to Demo limitations, an error might occur (possibly only when currently no track is playing).
    This error says something like "DragDrop registration failed". You should *not* respond "Retry" to the message.
  • When diacretic marks occur in the Track Name, currently Engine #3 won't play the track. unhappy
Notes on using Engine #3 :
Well, read the notes on Engine #3 once more in the contained Help.htm (search for #3 and you will find the relevant changes).
As off this writing, there is NO experience on how to get Engine #3 running on your Vista machine (and I myself have no PCs which aren't "destroyed" for testing because of the development environment).
Anyway, do as always, but select the #3 Engine from the combobox in XXHighEnd, and have further settings as you would have for Engine #2 (which is about the Sound Device you'd use with that).
Select tracks as you are used to, and ... press Play. If there's no sound, something is wrong. I can only hope messages accordingly will appear then.
Note that things can start to wrong only after pressing Play.
You all can try it if you like, but please note that although I will read your responses (which responses would be very useful anyway !), I hope to get some "experienced" information from those who applied here and with whom I will try to work it out. Whatever it is what happens, when you're stuk, please post the literal error message !
Thanks for helping in advance !!
Now good luck !
 dancing
Edit : It is now known that the zip below does not work. For further information and trials, see here : http://www.phasure.com/index.php?topic=70.0.
Edit2 : Removed the zip, awaitening a working version.
« Last Edit: June 19, 2007, 11:44:18 am by PeterSt » Logged
