April 20, 2025, 06:26:40 am *
Pages: [1] 2 3  All
Author Topic: No Track Given Error  (Read 43498 times)
KUOYAO
« on: January 13, 2009, 01:59:52 pm »
When using version w-7, I get a popup error message saying "No Track Given."  Then after several minutes or when I press "OK" it will continue playing.  Pls help.
Thanks
Asus P67 (Intel i5) -> W7 64x -> XXhighend -> RME AES32 -> Lavry DAC -> Pre-amp
« Reply #1 on: January 13, 2009, 03:04:25 pm »
Might that be at Attended playback ? (and only that !)
KUOYAO
« Reply #2 on: January 13, 2009, 03:12:27 pm »
I'm not using unattended play.  Now when I press OK on the error box, I get another error "no track found."  This problem did not occur with w5.
« Reply #3 on: January 13, 2009, 03:25:01 pm »
Ok, so this is what I noticed too, but thought it was caused by something else. Hmm ...
If you want to keep 0.9w-7 you can play Unattended. The problem is not there.
KUOYAO
« Reply #4 on: January 13, 2009, 03:35:09 pm »
You're right.  No problem using unattended.
« Reply #5 on: January 14, 2009, 06:09:17 pm »
KUOYAO,
45 minutes ago I sat down to solve this bugger, while yesterday I used the log and could not find in there what went wrong. And wrong it went all over.
But not today !!
I really don't know what settings I could have changed. Do you perhaps have a clue ?
And *is* anyone else suffering from this problem ? (you don't need to explicitly test this for me, but it could be that tou ran into it -> Attended only).
But ...
I am beginning to think this is a compiler error or something of the kind;
Yesterday I built in some debug commands, and in the end removed them all. The .exe is exactly as long as the January 12 version, but the files are not equal ...
Could you (or anyone who had the problem) try below XXEngine3.exe please ? Just unzip it into your current XX folder.
I'd put some money on it has been solved ... yes
Edit : Removed the zip which did not help.
« Last Edit: January 17, 2009, 02:36:47 pm by PeterSt » Logged
Leo
« Reply #6 on: January 15, 2009, 08:19:16 am »
I still have the problem with this extra version of XX. Attented play and 'no track given' with the second number of the list. Previous version could hold on a bit longer Happy
Leo
« Reply #7 on: January 15, 2009, 08:44:37 am »
Hi Leo, thanks.
Can you please tell me all the settings you use ?
What file type you play (FLAC etc.) ?
How long the first track is ?
How long the second track is ?
And if this is repeatable for that album ?
Thank you very much,
Leo
« Reply #8 on: January 15, 2009, 09:46:05 am »
files are wav (EAC based). Marcus Miller M2.
First song is 4:37.02 , the second is 5.39.02.
I went back to the previous exe, and had the same problem !
Restarted the computer with the previous version, that worked without the error for 4 numbers. I thought some things I would like to tell to Bill Gates....
On your request above  I replaced it with the 'upgrade', and it gives the track error at the same place again. But it plays on, which it did not before the restart.
I also sometimes get a gap at the end of  a number.
I'll keep you posted
« Reply #9 on: January 15, 2009, 10:05:44 am »
But what are your settings Leo ? all of them please ...
and
What do you mean by this (both cases !!) ? it can be important ...
Do you mean the XXEngine3.exe from 0.9w-6 ? do you mean a complete XX 0.9w-6 ? please be as accurate as you can, because usually knowing the differences or equalities brings the solution for a software bug.
Anyway, I myself find it the most strange that day before yesterday I could let each track end up in an error, and now not anymore.
Leo
« Reply #10 on: January 15, 2009, 12:22:41 pm »
After the error I went back to w7. And then had the same error as when using your separate zipfile.. Restarted the computer and then no problems with the original W7.
After that trying with the new zipfile and got the error again.
Settings are q1 at 4, No appointment, playerprio belownormn, thread high prio, split file at 200 Mb, start engine during conversion, copy to xx-drive, allow format change, attented play.Any more info you need?
« Reply #11 on: January 15, 2009, 02:28:55 pm »
No, I think I see all I want to see. Happy  Thanks !
« Reply #12 on: January 15, 2009, 06:12:16 pm »
Ok, I found something which was a. theoretically wrong and b. changed the other day.
I don't see how it can cause this (but many things are difficult to see), but it is in the area of "No track given" anyway.
Also, this is related to the speed of copying, and as we have found quite some times earlier : anomalies seem to happen often within the first tracks after a reboot.
Anyway, below zip is ready to try again.
I am sorry I can't test this myself, but as you have seen it may take quite some time to happen. Here I'm at a 12th track without problems. ... Says nothing.nea
PS:
Would have lost that money. blush1
* XXEngine3.zip (55.35 KB - downloaded 594 times.)
Leo
« Reply #13 on: January 15, 2009, 06:37:54 pm »
Hi peter,
I will try it in the next hour or so. In the meanwhile I have found another very peculiar thing with the volume control.
First it does not react during play, which did work with the course version. So procedure is now: stop the play, change volume, restart. I  can live with it but would love to be able to change volume again during play (in attented mode of course)
Another thing came up just now, I went from 21 to 19,5 and volume went down, really a lot. Going from 19,5 to 18 gave the volume at the originally expected level. This I repeated a couple of times to be sure it was repeatable. It is.
So Peter, don't worry, we will find things to keep you from skating on too thin ice Happy
Leo
« Reply #14 on: January 15, 2009, 07:05:17 pm »
oops Typo in the program ! could have been the other way around ... heat
PS: At the 29th track here. Still ok.
Pages: [1] 2 3  All
