November 23, 2024, 08:14:08 pm *
Author Topic: xx on networked pc will not activate  (Read 5295 times)
« on: January 12, 2009, 12:11:10 pm »
hi peter
i have a networked pc and I followed the procedure to activate - everything worked fine and a code was generated for the networked pc but it did not activate. I got a message that correctly stated what the code is on the target and a new generated code for the networked pc but it did not work. I did not want to publish the codes here but could email them to you if you require
all the best
« Reply #1 on: January 12, 2009, 02:37:15 pm »
You most probably did everything fine, but the procedure just doesn't work (anymore). Or at least not for everyone.
I just sent you a PM though (My Messages above). Please see there.
