November 23, 2024, 04:32:38 pm *
Author Topic: XXHighEnd Model 09w-6 (solves repeated etc. tracks)  (Read 7638 times)
« on: January 05, 2009, 07:55:51 pm »
This should about complete (but see at the bottom) the new memory management as was introduced per the 0.9w version.
  • If all is right the repeating of a track -after which playback stopped- has been eliminated.
  • At the end of a track a piece of it's beginning could be heared sometimes. Solved.
  • The "Split file at size" settings parameter now has a default of 100MB. This should cover for all means of (also hires) playback, and doesn't harm the "memory player" features at the same time.
  • Per this version now officially two subsequent DXD (24/352800) will play.
    Important : This only works at Unattended Playback !
  • Since a few versions back MP3 files would show "UnicodeTrack0001" at the Wallpaper Coverart followed by a ChangeWP error. Solved.
  • Cue Files with a track name of one position (e.g. : I) would error out on loading into the Playlist Area. Solved.
  • Albums without track numbers in their first positions which also couldn't get track numbers applied by XXHighEnd would error and not load into the Playlist Area. Solved.
  • With a click on the "V" label above the Digital Volume slider now the volume will go up with one notch.
    Note that the mousewheel can also be used to change the volume (after the slider has been clicked to make it the "active control").
  • The DAC Test (last option of the "DAC Is" combobox in the Settings Area) did not work anymore. Solved.
  • When XXEngine3 runs out of memory now in most of the cases a normal message about that is provided. In more rare cases still an "XXEngine3 stopped working" can appear.
Issue left : Upsampled tracks from Cue File albums may end with an "XXEngine3 stopped working".
Similar might happen in general with Upsampling (hence something is not right in this area).
Edit : Rips with DBPowerAmp cause Crack Detect messages in between tracks. See Problem on 09-w6
* XXHighEnd-09-w6.zip (4567.56 KB - downloaded 749 times.)
« Last Edit: January 07, 2009, 02:01:39 am by PeterSt » Logged
