November 23, 2024, 09:47:30 am *
Author Topic: Most convenient Storage Structure ?  (Read 38536 times)
« Reply #15 on: August 01, 2007, 05:37:36 pm »
Hahaha, I just tried it. It does work, but not how we'd want it.
a. XX will start from the location where the WAV sits, implying that it can't find the necessary files, and therewith thinking it's a demo version;
b. When you select several tracks, Rightclick - Open, XX starts as many times as tracks were selected.
Currently I'm not sure what to do about that ...
Btw Klaus, your solution here is similar to my "ThumbsPlus" solution, but the ThumbsPlus solution would have everything organized independently from the physical structure. This is with Keywords (as many as you like), Archives and queries making use of that and further properties. However ... I see similar in Vista as possibilities (I mentioned this a few posts back, I think).
« Reply #16 on: August 01, 2007, 07:13:10 pm »
Hi Soundcheck,
You were  talking about how to define XX as default audio player for .wav in the registry. Can you explain how to do that?
I think currently this is not possible, because XXHighEnd doesn't (on purpose) come with an official install. So Windows wouldn't know about it.
But indeed (I think) I could change the Registry for that ...
I really really like that you haven't done an "official install".  Right now I have two versions of XXHE on my machine and will have a third version, h, on the computer soon.  If you did an official install wouldn't windows only allow one version to be run (overwriting the previous version); maybe not but... ?  By just unzipping XXHE and creating a shortcut to XXHighEnd.exe from each of its own version folder (I have shortcuts named DXXHE, FXXHE and will have HXXHE so I can listen for differences...).  I can then go and just delete a folder of a version I no longer care for and don't have to worry that the uninstall of Windows didn't get everything... registry messing?
delete/move this post if you'd like after reading PeterSt
« Reply #17 on: August 01, 2007, 07:17:00 pm »
Again... if you do figure out how to associate tracks with XXHE, how will it know which Version of XXHe I want to listen to?  Until out of beta and we are all sure which version to use... keep it simple like you have it now.
« Reply #18 on: August 01, 2007, 07:22:06 pm »
Ha ! you are sure right on that one !
But indeed, that's why I tried to keep it as simple as possible, and in the mean time not messing with "your" PC ...
