November 23, 2024, 01:44:29 pm *
Author Topic: Error message II - W5  (Read 5318 times)
RX1
« on: December 18, 2008, 09:35:52 pm »
Hi
I just installed w5. After un-demoing and setting up music folder I restartet. Now, when I start XX and when I go to library I get a error message reading "VirtualMode is not supported in Tile view."
I can not see or select any item of the liberary, hence not play anything either.
Do you know what I can do to fix this?
Br Rolf
HP Pavilion dv9695, Hagerman Tech HagUSB, dCs Purcell, dCs Elgar plus, McIntosh MC2000, BAT VK-5i, Avantgarde Duo
0.9w1a #3, Q1=0, PlayPri=Low, Thread=RealTime, 16bit/48.0KHz
« Reply #1 on: December 18, 2008, 10:44:54 pm »
Hi Rolf,
For now the quick solution (which should work because it works here) : set the combobox at the right to TextUnder.
I will look into it of course.
What version were you using while your setting worked ? (and to be sure for me, what was your setting for that combobox ?)
Page created in 0.108 seconds with 19 queries.
