November 23, 2024, 04:07:53 pm *
Author Topic: Load previous settings  (Read 6089 times)
« on: December 18, 2008, 06:22:33 pm »
Question: Is it possible to make a special settings file. Meaning i do not load a new XX model over the previous one. When you do not do that a question is asked to load in the old settings. (Wich do not work offcourse) maybe you can make a file or such that can be ticked in a old XX map (wich contains the right settings) to make it work....
Or do you have something else in mind?
Grtzzzzzzz  Happy Happy
« Reply #1 on: December 18, 2008, 07:50:15 pm »
Actually I don't know how it works really. But truth it that using different folders for the different versions of XX make this fail.
You will recall I asked you all about your experiences on this, and now I have to do something about it ... which I still didn't.
I am always using the same folder, and then there's no problem. Problems start at switching folders.
But now this major "memory" task is behind be, I will be having time for it.
« Reply #2 on: December 18, 2008, 08:26:04 pm »
The thing you can do also is when you have to put in the activation code (That's also something you have to do when making a new folder)  that there is a option to load in the code automatic from a kladblok file.
Page created in 0.162 seconds with 19 queries.
