November 23, 2024, 01:51:20 pm *
Author Topic: Can't undemo.  (Read 6300 times)
LarryK2
« on: December 17, 2008, 11:30:06 pm »
I had some work done on my PC and the "full" xx highend no longer works.  I've reinstalled the demo version, but the activation code doesn't work now.  Also, the cursor to change position on the track, and engine 3 don't work (message claims that I'm not using Vista).
Help.
Larry
Ava12
Headphone Audiophile
« Reply #1 on: December 17, 2008, 11:50:46 pm »
The activation code does only work one time (as far as I know).
What you need is the XXHighEnd1xx.dat file, which created itself when you activated your XXHE.
This file contains your activation and needs to be copied everytime you upgrade XXHE to the new folder.
but if youlost your XXHighEnd1xx.dat file, Peter will propably give you a new one if you ask him kindly thankyou  Wink
LarryK2
« Reply #2 on: December 18, 2008, 02:51:44 am »
Thanks for the info - I can't find the original file, so I'll have to ask for another.
« Reply #3 on: December 18, 2008, 07:22:19 am »
Ah, you don't even need to ask very kindly since you're just entitled to it.
I will send you a PM ("My Messages" above) on what to do.
But this is strange. Can you quote that message literally ? of paste in a screen copy of it ?
Page created in 0.115 seconds with 19 queries.
