November 23, 2024, 09:59:59 am *
Author Topic: Getting Error Message  (Read 8383 times)
glynnw
« on: December 09, 2008, 10:56:02 pm »
I installed 09-W4 on my laptop and get the following message when I click on album from the library area to play it.  Got the same message with 09-W3 - on most albums I tried - a few played OK.  Have not tried either W3 or W4 on my dedicated music PC - still happy w/0.9-V7
=12=System.ArgumentOutOfRangeException: Length cannot be less than zero.
Parameter name: length
   at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length,
Boolean fAlwaysCopy)
   at XXHighEnd.XXHighEnd.ExistsAsCueFile(String FileName)
   at XXHighEnd.XXHighEnd.btnLoadPL_Click(Object sender, EventArgs e)
« Reply #1 on: December 10, 2008, 09:44:41 am »
I think I recognize this as something I do wrong in the program when first the name of a .CUE file is "wrong";
Please go to the folder where you have such an album that produces the error, and check for the large .WAV file, and look for the exact same name of the .CUE file. Thus
Jazz at the Pawnshop 1.WAV
Jazz at the Pawnshop 1.CUE
and nothing else !
Take care that you can see the exntensions (which is a Windows Explorer setting) otherwise
Jazz at the Pawnshop 1.WAV.WAV
shows as
and although the first will play allright, the .CUE file does not comply to the "equality" rule above. This will still be named
Also take into account that Cue files are not supported for FLAC. So, if you have a large FLAC file, it must be converted to WAV, or split into the individual (track) files.
Let me know whether this helped.
glynnw
« Reply #2 on: December 10, 2008, 04:32:43 pm »
I don't know how to see more of the file extension info.  All my files were ripped from CD using dbPoweramp as WAV files, if this helps.  I don't really know what a cue file is or if I have any.
« Reply #3 on: December 10, 2008, 04:59:47 pm »
Ok. Can you show me the contents of such a specific folder ? (hence can you make a screen copy of it, and post it as an attachment here, which you can do under "Additional Options" at the bottom when posting ?)
glynnw
« Reply #4 on: December 10, 2008, 11:49:53 pm »
I will attach a screenshot - if you need more, then let me know.  I can load and play individual tracks.  I downloaded a flac file and it played OK.  I also installed 0.9-w4 on my music only computer and got the same error message when I double clicked on an album facing in the library area.
« Reply #5 on: December 11, 2008, 09:27:33 am »
Well, nothing wrong with this.
Tonight I will try to let things go wrong myself as well. But if you, in the mean time, see a pattern in which go right and which go wrong, please let me know !
