April 05, 2025, 05:25:14 am *
Author Topic: Newbie questions.  (Read 24250 times)
twystd
« on: November 25, 2008, 06:24:47 am »
Hi Peter
After my first attempt at a music server fell short of being able to use XXHighend (too little RAM capability). Sad I have gone for version 2, which is an Aopen mini 965-D. I have an Intel Core Duo T2700 2.33 Ghz processor (676Mhz) with 4Gb of RAM (2 bays 2GB each). I also have to get the firewire cases for my external hard drives, as I originally bought USB cases. BTW, I am using a very small 8 inch touch screen LCD monitor. This little system will set on the coffee table in front of my listening position. I assume this is now enough to take advantage of XXHighend, am I correct? I also have built Doede Douma's DDDAC 1543 Mk2 NOS DAC. The DAC will be connected to the computer via an Opticis laser USB extender. This will run a DIY tube system, with 99db efficient speakers.
Which version of Vista should I buy for the best sound (home basic, professional, or what)? Since this is a dedicated music server, sound quality is the only issue. I do hope you are patient with me, although I can design and build a mean tube amp, I know VERY little about software. Also, which version of XXHighend should I use?   scratching
Finally, do you think a person that has good Internet skills and a good understanding of XP, but knows nothing of programming, can utilize XXHighend successfully, and do you think the computer equipment is enough to fully utilize XXHighend? I know, a lot of simple questions, but I want to avoid any more silly mistakes on my part. I'm looking forward to finally having a working music server!  smile
twystd
« Reply #1 on: November 25, 2008, 03:06:32 pm »
Well, first of all I am kind of specifically around to help out *anyone*, but this is not always an easy task and may require patience on "your" side. Also, while XXHighEnd started to be as simple as possible for everyone, it turned out into something which is now more complex than I want, but, for the good cause of better sound quality.
Anyway, don't be afraid to ask and don't dare to feel stupid about it !
Having said this, I don't see much wrong with your current setup, including the firewire connections to the hdds (instead of USB).
I don't know about that USB extender, and generally (!) devices like that do not make sound better.
Btw, you do know that USB length can be 10 meters easily ? as long as the DAC is not powered by it. And if so, you could provide your own power means.
Btw, what is the reason to use the extender anyway ? I suppose your PC is located near the audio equipment, and the 8" monitor is fed with the longer cable ? (can be 15 meters easily with the proper cable, and the USB connection you might need (touch) for that can be extended in many ways, as you will know).
The version of Vista doesn't matter, but if it does I didn't hear it from anyone in here.
One thing might come handy (sometime later) : Only business and ultimate allow for RDC (Remote Desktop Connection), meaning that you could have a small laptop on the coffee table with wifi connection to the main PC, and control everything (this connection is not audio related).
(I think I told this in an earlier post, twystd related).
Today I say yes, but tomorrow that may change. Many things are going on, and we keep on learning.
It works the other way around as well : requirements get less, like the memory which is allowed to be lower since the last version (0.9w-3).
Currently I advise to use 0.9v-7 which sounds better than above mentioned version. But I'm working on that.
Anything else ? ask away.
twystd
« Reply #2 on: November 25, 2008, 05:01:36 pm »
Thanks for the reply Peter. The reason for the extender is to electrically isolate the DAC (powered by a filtered regulated battery power supply) from the switching power supply noise from the computer. The USB extender is powered by a switching power supply, but I am replacing that with a filtered regulated battery supply. The laser extender (optical cable), connects my computer, which is on the coffee table, to the DAC, which is a short distance away (3 meters) on my audio equipment rack. Do you think this is a good application, now that you know how I intend on using it?
Right now, I'm not too interested in the Remote Desktop Connection feature, as I built my system very small. It will be right in front of my listening position, within arms reach. I decided to go small for convenience, and for portability as well. The portability issue is so that I can put the music server, monitor, and associated drives all in a tiny rack and put a handle on it, so I can transport it to friends houses, and local audio meets for demonstration purposes. The RDC feature might be nice in a future version, I just have to decide if the flexibility is worth the added cost.
It's going to take a couple of weeks to get the whole thing finished and some music ripped (PlexTools), then get ready, as I'm sure I'll have a few questions!8^)
twystd
« Reply #3 on: November 25, 2008, 05:43:36 pm »
No ... Happy
But for net result it is another thing of course. So net you may be better off now. Optimal is another thing. Otoh it is a kind of given fact for your setup (hence the DAC).
Just carefully listen to the pros and cons of each situation (with / without the extender).
It is all not *that* easy of course ! prankster
« Reply #4 on: November 26, 2008, 03:05:33 am »
I tried an optical usb extender with a battery supply when I was using the usb of my dac... It was noticeably worse than the generic 6 foot cable I had.  USB, at least for my dac, was noticeably worse than spdif, which I now use.  I don't recommend usb anymore,,, don't know about the latest "asynchronous" that wavelength uses,,, maybe ok?
« Reply #5 on: November 26, 2008, 07:49:22 am »
Thanks for the reminder Peter.
I've been using RealVNC for ages now to control my laptop from my study PC ( and vica versa ) and it never occurred to me to use the laptop to control my music server with it. DOH !
I loaded up the RealVNC Server ( Enterprise version ) on the music server, made the appropriate configurations, and connected to it from my laptop sitting on .. err .. my lap ... while sitting on my recliner. No more neckstrain trying to look at the music servers monitor off to one side in the distance .. excellent !!
Screen updates on the laptop were fine .. essentially real time. As I use scheme 1 for my processors balance any addition CPU loads were handled by the CPU not running Engine#3. There doesn't appear to be any perceivable degradation in SQ.
Next step I guess is to see if one of those little EEEPC's might do the job.
I'm a happy chappy  very happy
twystd
« Reply #6 on: November 27, 2008, 08:32:10 pm »
Hmmm... Don't know a lot about this, but I think my DDDAC 1543 is asynchronous. It uses a I2S bus and re-clocks with a Tent Labs clock. Any comments?
twystd
« Reply #7 on: November 27, 2008, 08:42:11 pm »
twystd
I've heard I2S is a good direct link.  As for usb, I found when using it that different ports on my laptop didn't sound the same and there was one that was better than the others... so try all your ports.  I read and was going to try a usb add on card, someone felt this was better... maybe? gl
twystd
« Reply #8 on: November 30, 2008, 01:13:03 am »
Does it matter sound wise if I use a ATA150 or ATA300 internal hard drive (both 5400rpm), they both have the same 8MB buffer. My computers controller is ATA300, but I have the ATA150 drive already, will the faster drive effect the sound? I don't mind spending another $60.00 if it will sound better.
 I'm planning on running the operating system, and the XXHighEnd on the internal hard drive, all music on the external drives through Firewire, and a Bluetooth keyboard. The only things on the USB bus are the DAC, and the Plextor CD reader. Obviously the CD reader and the DAC won't be going at the same time, so that leaves the DAC on a "dedicated" USB bus. Do I have this correct?
twystd
« Reply #9 on: November 30, 2008, 05:00:51 am »
Hi twystd,
I'd say the 150 and 300 connection just can't matter to sound. Not that I have heard of and not that I can ever imagine how.
Be careful with the bluetooth keyboard, because again that is an ever "sending/receiving" thing full of interrupts. I would not do that, unless it was proven to be harmless (and not the other way around). This counts for every similar thing like infrared and wifi. E.g. I have wifi, but the access point certainly isn't connected to the audio PC (nor does that have a wifi connection itself).
twystd
« Reply #10 on: December 03, 2008, 08:44:26 am »
Hi twystd,
I thought that by going with an internal bluetooth card, that it would get one more device (keyboard and track ball) off the USB bus. If I understand you correctly that the bluetooth sends and receives even though I'm not typing or moving the track ball, and that this send/receive is interrupting the processor? So you would recommend a standard USB keyboard then? Its amazing how much I have to learn about this PC music server thing! Shocked
twystd
« Reply #11 on: December 03, 2008, 09:03:05 am »
Mwah ... I am not sure bluetooth is sending/receiving without doing anything (but I think it does like wifi), but in the end it is not only about that. It is about that you sure want to move your trackball and type a key here and there, and then this stuff usually has priority over everything (which is kind of logic) and then the sound breaks ... (ticks and stuff).
On the matter of this latter you can easily try it. The "polling" thing can be checked for, although this is not easy for the unexperienced (for bluetooth I wouldn't know how to do it either, currently). This won't break sound, but may (!) degrade it.
Stupid computers.
But luckily we are so far with it, that it sounds way better than the CDPlayer !
twystd
« Reply #12 on: December 03, 2008, 09:39:42 am »
Stupid computers.
Okay Peter I don't want to take any chances, so USB cabled keyboard it is. Don't mean to drive you nuts wacko, but which version of Vista should I get 64 bit or 32 bit? I'm thinking 32 bit because I've heard there is a driver availability issue with 64bit, and the DDDAC1543 MKII is kind of an old design.
twystd
« Reply #13 on: December 03, 2008, 11:48:06 am »
The only thing 64 bit will bring more is supported memory, which ... you can't utilize anyway (2GB max can be used by XX). Also, by now (version 0.9w-3) it is not necessary anymore.
I think, though, your DDDAC will just work on any legacy USB driver, including the one within 64 bit Vista.
I hope I am a bit clear ...
twystd
« Reply #14 on: December 03, 2008, 04:27:56 pm »
All the pieces for the music server will be here in about a week, but I've looked around and don't see where to pay for and download the XXHighEnd player. Lord knows you've more than earned it in my case. smile
twystd
