November 23, 2024, 12:24:35 pm *
Author Topic: ChangeWP behaviour  (Read 7009 times)
Eric
« on: November 23, 2008, 08:47:20 pm »
Every time I start and stop XXHE, a new ChangeWP process is added to the list of running processes. In addition, the wallpaper does not appear. I am on the newest Versions.
Any advise ?
Cheers, Eric.
« Reply #1 on: November 23, 2008, 09:30:02 pm »
I forget where all the threads are.  But I think if you just keep shutting it off and restarting XXHE, it eventually works it way out.  or
If you follow this guide made by Peter in shutting stuff down you'll find the one that stops this ChangeWP thing... I'd have to read through to remember and find it, so I'll leave that to you Happy
Put your frontend system in your signiture helps everyone help you and, are you running V7 or the W series of XXHE?
http://www.phasure.com/index.php?topic=548.msg3933#msg3933
« Reply #2 on: November 23, 2008, 10:05:06 pm »
Hi Eric, it was described here : A few questions about Vista behaviour to you.
I Assume this helps you ?
Btw, somehow it seems that things go further than described in there, because that was about reverting to an older version.
scratching
Eric
« Reply #3 on: November 24, 2008, 09:37:34 pm »
Thanks Peter,
running HDI.exe once as administrator helps.
I hope that someday this workaround won't be needed anymore.
Cheers, Eric.
« Last Edit: March 15, 2009, 08:54:17 am by PeterSt » Logged
