November 23, 2024, 04:35:23 pm *
Author Topic: Clics  (Read 5216 times)
kjelg
« on: November 17, 2008, 12:16:24 am »
This is first time I try with a dedicated setup, and I'm very pleased with SQ. The problem is a click (short <1 sec interup) one or more times during play. I have tried several other settings than described below, but no big change. I also tried playing the music directly from HD on PC instead of using NAS HD.
One more thing, a message pops up every time I start xHE: xHE not run as Administrator..
I would think I am running as Administrator, that is I appointed a username to also be administrator when PC was setup. Don't know if this could have any influence?
Regards
Kjell
Dell XPS M1530, Dual core processor T8300, 4GB Ram, D-Link 323NAS HD, 1 GB-LAN, Firewire, Fireface400, Electrocomp. ECD1 DAC 24/192, Q1=4/ V=-6db/ Engine#3/ PlayerP=nothing/ ThreadP=realtime/ xHE 09-v7
« Reply #1 on: November 17, 2008, 12:29:54 am »
Hi Kjell,
Uh-ohh, these kind of things usually are nasty ...
Do you have an infrared keyboard ? switch off the IR feature and try again.
Do you have a wireless connection somehow (or an accesspoint connected to the PC) ? switch it off an try again.
Other means of "through the air" ? same ...
And for now : make sure the Split Lare Files setting (Settings area) is at 2500 (when the clicks have gone you can do what you want with it).
You are not the first with a (Dell) notebook and these kind of problems ...
Look here : Vista Users ... prepare yourselves ...
I sure hope you can solve it !
(but let me know when not)
Page created in 0.104 seconds with 19 queries.
