April 20, 2025, 02:01:24 pm *
Author Topic: Error message in versions 2 and 3  (Read 5991 times)
glynnw
« on: November 16, 2008, 08:12:30 pm »
I get an onscreen  message when I go back to the computer and hit enter to get it going (notice how I use all the correct technical terms) after it has sat with blank screen for a while .  I just have to click on it to make it go away, but it becomes a PITA.  This started when I downloaded last 2 versions - 2 & 3.
Message says: =03=System.ComponentMoel.Win32Exception:The operation was canceled by the user
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfostartinfo)
at System.Diagnostics.Process.Start0
at ChangeWP.Module1.HideIcons2(String&Action)
« Reply #1 on: November 16, 2008, 08:24:25 pm »
At which version this wasn't happening ? (0.9-w1 ? earlier ? -> just your experience, you don't need to explicitly try)
And can it be related to A few questions about Vista behaviour to you ? otherwise it seems quite some coincidence ...
scratching
glynnw
« Reply #2 on: November 16, 2008, 09:27:59 pm »
Yea, I don't recall getting this prior to version 2.  It doesn't happen all the time.  Today I deleted all the versions and re-installed 0.9v-7 (simply to listen to the sound of the older version) and have not yet got this message, but then, it's only been a couple of hours.  If it occurs with this older version, I will let you know.  I also took advantage of my 90 day Vista warranty and have submitted this to Microsoft - I'll let you know what they say.  Could changing the size of my wall paper to 800 have anything to do with it - this is a recent change I made.
FYI - last night listening to 0.9v-7, I felt my system sounded better than it ever has.
Page created in 9.6 seconds with 19 queries.
