April 06, 2025, 03:28:33 am *
Author Topic: Help with Fireface 400 and Vista  (Read 17917 times)
Chris V
« on: June 12, 2007, 05:49:01 pm »
Hi Peter
My new Vista PC is here clapping.
XX is loaded together with the appropriate software and seems to be operating OK, however I am getting no sound through the Fireface.
I went to audio properties to select SPdiff as before. There are lots of options shown for the Fireface but they are all the same Shocked, gone are the options for spdiff/ADAT/MME etc, etc
I am guessing that perhaps the Fireface software needs to be upgraded/downloaded to get it to work on Vista. What do you think?
Cheers Chris
Then to SW1X Signature DAC
« Reply #1 on: June 12, 2007, 05:58:23 pm »
That sure is so Chris. But : where did you get the old drivers from ? from the withgoing CD I suppose ...
Those are way old ! (and indeed cause the problem you describe).
Go to this page : http://www.rme-audio.de/en_downloads.php?page=content/downloads/en_downloads_driver&subpage=content/downloads/en_downloads_driver_fireface
Look whether you need new firmware first before you actually upgrade; If you download the driver there will be a readme where (usually) the needed firmware is shown.
Think about a structure to keep the old versions for future needs, because it may happen that a new driver doesn't sound good.
Note : I'm on 2.63a for the 800 and I don't have problems with it.
Chris V
« Reply #2 on: June 12, 2007, 06:10:44 pm »
Just looked at the properties of the software on the supplied CD.
Driver date 19.06.06
Driver Version 2.55
Hardware Revision 1.52
As you say these are well old dntknw
Chris V
« Reply #3 on: June 12, 2007, 06:46:27 pm »
Computers can be soooooooooooooooo annoying grazy
Have downloaded the firmware, run it (what appears) successfully and then it says I need to shut down for it to take effect.
I do this but the firmware doesnt upgrade. Help!
« Reply #4 on: June 12, 2007, 06:49:25 pm »
Uhhm ... the Fireface should be shut off (10 secs or so) and on. That is, for the firmware. Party
For the driver it's the PC.
Chris V
« Reply #5 on: June 12, 2007, 06:54:15 pm »
Bloody hell shout shout. I was turning off the PC.
All is well with the firmware update.
Now for the driver software
Chris V
« Reply #6 on: June 12, 2007, 07:55:53 pm »
More problems sorry
I download the new drivers as a zip file, extract all 13 files, than find the two .exe file amongst them and run them, but nothing seems to happen and even after rebooting both the PC and the Fireface the driver software has not been updated.  blush1
Chris V
« Reply #7 on: June 12, 2007, 08:15:39 pm »
Just remembered you have to update drivers from the devices settings. Will give it a go
Chris V
« Reply #8 on: June 12, 2007, 08:18:08 pm »
YESSSSSS drivers updated. Nothing as sweet as a problem you solve yourself drinks drinks drinks
electrosound
« Reply #9 on: June 12, 2007, 08:31:05 pm »
Hahaha great  drinks
Marco
Toshiba Satellite Pro, 500Mb memory, XP => USB => PCM2707 USB converter => DIY 2X TDA1541 Crown => CCS Tube output => SE 300b => DIY horns with MD3 for mid high, Beyma G350 for mid low
Chris V
« Reply #10 on: June 12, 2007, 09:01:52 pm »
We have music drinks drinks Party Party drinks friends
