November 23, 2024, 07:06:18 pm *
Author Topic: Capless playback in version 09w-3  (Read 20574 times)
« Reply #15 on: March 10, 2009, 12:59:32 am »
    .....on a track of 6 minutes sometimes two times a short brake in the sound and i hear the sound of the external harddisk spinning up and down. Strange because i thought that all the tracks were playing from the internal harddisk! (Copy to XX-drive by standard). I have changed this “Split file at size” setting back to 700MB. Why do I hear this external harddisk spinning up and down during playback?  [/i]
Today i have done some tests with the split file setting of 12 MB. It's difficult to reproduce this error. On the second track of Brian Eno (now plays capless) i can reproduce this behaviour of two or three breaks in the sound and the spinning of the external harddisk (I:). Maybe it has something to do when there are capless tracks and maybe the duration of more then 7 minutes?????
See attachments.
Drive I: is the external drive.
Drive D: is music route and data folder
I'll hope you can found a trace in the attachments.
Johan
* X3-20090309-230942.log (14.13 KB - downloaded 474 times.)
* XX-20090309-225528.log (18.8 KB - downloaded 449 times.)
« Reply #16 on: March 10, 2009, 10:01:58 am »
Found it !
Or at least for the case you showed;
What you did here (I think), was bringing up XX again, and reposition the time slider. But it also happens when you change the volume.
I know, this all goes unnoticed since 0.9x-4, but in the mean time sneakily the file changes. So, at first it plays from the internal drive, and at e.g. a volume change it switches to the external drive again.
If you never touch anything after a first start of playback, all should be ok.
Btw, in the XX log file these two lines exist for each track :
Short Name initiated-1 : I:\Music\ELECTR~1\BRIANE~1.PET\2001-D~1\03-LIK~1.WAV
Short Name initiated-2 : I:\Music\ELECTR~1\BRIANE~1.PET\2001-D~1\03-LIK~1.WAV
and when they would have played as intended they would have looked like
Short Name initiated-1 : 03-LIK~1.WAV
Short Name initiated-2 : 03-LIK~1.WAV
In X3 it is more direct :
Music file found : I:\Music\ELECTR~1\BRIANE~1.PET\2001-D~1\03-LIK~1.WAV
should be
Music file found : 03-LIK~1.WAV
So you can check it when you hear spinup the disks.
Something to do again ...
« Reply #17 on: March 10, 2009, 06:50:52 pm »
Solved for the next version (0.9x-5).
