April 07, 2025, 02:55:40 am *
Author Topic: Problem w 0.9W-3  (Read 5727 times)
glynnw
« on: November 12, 2008, 06:59:34 pm »
When I double click on an album cover in the Library section, sometimes the tracks appear in the playlist and it plays fine, but with some albums I get this message and nothing happens:
=12=System.ArgumentOutOfRangeException: Length cannot be less than zero.
Parameter name: length
   at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length,
Boolean fAlwaysCopy)
   at XXHighEnd.XXHighEnd.ExistsAsCueFile(String FileName)
   at XXHighEnd.XXHighEnd.btnLoadPL_Click(Object sender, EventArgs e)
« Reply #1 on: November 12, 2008, 10:58:16 pm »
I will look into that !
Thanks for pointing it out.
Page created in 0.011 seconds with 19 queries.
