April 20, 2025, 07:24:46 am *
Pages: 1 2 3 4 5 6 [7] 8 9 10  All
Author Topic: My SSD install  (Read 142271 times)
« Reply #90 on: May 21, 2009, 10:20:53 pm »
I think this is a XX glitch, when try to make a gallery.
With to much albums at once.
It run out of memory, OK
After deleting everything, I stayed behind with 30GB on the SSD
Now I've copied my previous Gallery to the SSD.
And have a total of 46 GB on C:
Gallery = 15GB, OS=12???, where is the rest
How big it was I don't remember
 roy
« Reply #91 on: May 21, 2009, 10:39:35 pm »
Here it is rather consistent. 50.3 ~ 50.4
Keep in mind though that this is - or may be to a large degree determined by the cluster size. For the OS disk, assuming all those small Gallery files will be there, this should be the smallest. This, opposed to the disks holding the real music files, which should be the largest (64KB).
If you don't pay attention to this, each small Gallery File will consume 64KB, while actually it is some 100 bytes only. 64,000 time less ...
Now watch my 274,000 files (the largest part is Gallery files). Times 64,000 I think this is over 17GB.
Moral : always think of (a) the tradeof between faster reading at large files but slower reads on small ones (when cluster size is large), and (b) slower reads on large ones but faster reads on small ones (cluster size is small).
Submoral : when choosing for (a), you will loose disk space on many small files, and when choosing for (b) you will have utilized disk space optimally.
You may need to read it 5 times, but it means that disks containing small files merely must be formatted with a cluster size meeting that small size as good as possible, while disks containing large files *are allowed* to have a cluster size meeting that (and 64KB is far far less than the 20MB ++ files containing music).
What about sleeping on that ? Happy
PS: Good that you bought a 64GB SDD ... hehe
« Reply #92 on: May 21, 2009, 10:45:22 pm »
BUT
(... I thought to put this in a separate post)
this is not your issue. Look at the "Size:" and "Size on disk:" which is exactly what I was talking about. In my case as well as in your case there's hardly a difference, which will be the case because the smallestcluster size is the default (and the smallest is the best for the OS disk, as well that it is the best for the Gallery files). Keep in mind your music disks though, which really should have the largest cluster size, with which you gain much speed, and don't loose disk space upon.
So ... where did your bytes go ?
Q : how much discount did you get ?
swoon
« Reply #93 on: May 21, 2009, 10:55:09 pm »
OS is on standard cluster size
And CD DB is on 32Kb, I thought so.
Never really understood the acual meaning (more or less), but now I do.
Why did'nt anyone mentioned this before.
With discussion on 30 or 60 GB??
Thnx Peter
« Reply #94 on: May 21, 2009, 11:08:37 pm »
swoon
Don't care about money just music!!!!!!!
Thnx for quick response, Peter.
« Reply #95 on: May 21, 2009, 11:16:54 pm »
You are perfectly right. These are very useful tips (merely because of speed), and while I apply them all my life (ok, nearly), I never thought of mentioning it, nor did I think about it at people with response / speed problems. So, my bad I guess.
Anyway, you have it right (as I actually pointed out already), which leaves the reason in the blue for now.
If you make all unhidden files show (like I have), maybe those files are then counted in as well (what about a 20GB Swap File hehe).
« Reply #96 on: May 21, 2009, 11:32:57 pm »
Pagefile is shut of, (don't no if it's best solution but having 8GB and internal memory is faster)
I read a part of your discussion about it but it went nowhere.
Were can I find my pagefile.
So I can delete the content.
« Reply #97 on: May 21, 2009, 11:46:23 pm »
Not sure.
But with LESS than 8gb with Vista is better to have >=mem of swap.
« Reply #98 on: May 21, 2009, 11:52:09 pm »
Sorry, with less then 8gb on or off
« Reply #99 on: May 21, 2009, 11:55:40 pm »
In my last picture : the one but last line (pagefile.sys). In the root. If it's shut off it may not be there at all (hence won't consume space).
Oh well, be glad you have a 60GB SSD sold as 65; my previous one was 56, also sold as 65.
A nice on-going hoax btw. 1MB = 1024KB and 1GB = 1024MB, which normally makes the difference (so any 1TB disk actually is 931GB).
The difference is more than the size of your OS disk !!
thankyou
« Reply #100 on: May 22, 2009, 04:03:20 am »
But still would like to know where my 12GB went
On the left your setup.
35GB used on C: but says 46GB  dntknw
« Reply #101 on: May 22, 2009, 07:14:16 am »
You have another partion on there ... yes
« Reply #102 on: May 22, 2009, 07:17:44 am »
No, not by my means nea
« Reply #103 on: May 22, 2009, 07:35:49 am »
But the 12GB I'm missing is exactly the same as the gallery I tried to load in XXHE with save gallery.
Looks like XX put it on a temp location somewhere but it shows nowhere.
The files didn't TRIM maybe, idk
So Vista thinks they are still in use.
Can this even be possible ?
« Reply #104 on: May 22, 2009, 07:47:39 am »
*If* they are in a hidden place, this will be onder the C:\Users folder somewhere (Vista Shadow stuff).
Open a Dos box (RUN from the startbutton - cmd), do CD Users (or CD Gebruikers), and in there type
dir *.mta /s
If nothing shows up, it's not in there as well. If it does, we'll see further.
Page created in 0.065 seconds with 16 queries.
