April 20, 2025, 07:25:01 am *
Pages: 1 2 3 4 5 6 7 [8] 9 10  All
Author Topic: My SSD install  (Read 142272 times)
« Reply #105 on: May 22, 2009, 07:54:08 am »
Nothing found,
I know almost for sure (I've I could make a decent back-up) and I back it up and put it back
it gives me 12GB back.
After cleaning disc ofcourse
« Reply #106 on: May 22, 2009, 08:08:13 am »
And backing up becomes rather important after spending several hours setting up Vista and/or W7.
You want ONE thing 100% working back-ups.
Also needed when flashing your SSD.
Once I can make decent back-up of a OS,
can do some with W7.
btw cant find Adonis anywhere on the net.
Back-up of OS is essential for all XX users !!
Just went into stravinsky here, hehe (4,26,26,0,0 seems to work well for me)
« Reply #107 on: May 22, 2009, 08:17:29 am »
That's because it's Acronis. Sorry. http://www.acronis.nl/promo/ATIH/true-image-2009.html/?source=nl_google&ad=backup+disk&c=2831869134&k=backup&gclid=CPXnnteiz5oCFQeA3godiBeZRw
Please note that once upon a time this was a major backup program. Nowadays I'm not so sure.
« Reply #108 on: May 22, 2009, 08:19:21 am »
Btw Roy, I don't see any hidden files in your last picture (the one next to mine). And I'm sure there are (in the root) ...
« Reply #109 on: May 22, 2009, 08:28:04 am »
 have these settings for 2 days
* Vastleggen in volledig scherm 22-5-2009 82256.bmp.jpg (207.23 KB, 800x588 - viewed 857 times.)
« Reply #110 on: May 22, 2009, 08:32:24 am »
Acronis isn't working either for me, Thought you ment Acronis.
I did it for me just once after that I wouldn't work, maybe because of crack.
Have to try some other stuff but as you know it takes a lot of time,
But most people make a back-up without trying it really, You think you are save, EEEEEEEhhhh Not!
« Reply #111 on: May 23, 2009, 08:59:15 am »
Ugh,
Now W7 (tweaked) on SSD,
Works for me now, DPC Latency around 90-140 - processor on 0% (or almost)
No peaks in DPC lat.
I'm NEVER EVER going back to Vista.
SQ so much better in W7
And do understand this is just Beta with Beta drivers, but even now it sounds 10 times better then Vista.
Much more relaxing now. (verry happy)
And a BIG pro is: It only gets better.
Roy whistle
PS: Did you know that a single SSD is even faster then RAID 0 with SSD
« Reply #112 on: May 23, 2009, 09:55:43 am »
Murning,
And I've got my 12GB back,
Golden setup SSD, W7 (Tweaked) and XXHE Unattended 4,26,26,0,0 or 4,30,30,0,0.
And after a couple of minutes all HDD switches off. so no noize from them either.
Can finally say, money well spend!
« Reply #113 on: May 23, 2009, 10:32:55 am »
Just played Yello - One Second
Man, falling of my chair here, It swings it rockes!!
It's all sounds so right, best experience I've had in a long time.
This, coming out of my system ?!? That loud
What the f*ck
« Reply #114 on: May 23, 2009, 11:58:22 am »
Ah, so finally you are there, right ?
Now wait until you here "my" One Second. I've put through some drastical changes lately ... teasing
Anyway, thanks for pointing out W7 sounds better, while I can't switch to that until some dutch version comes along (what will it take ? a year ?). CryCry
hehe
« Reply #115 on: May 23, 2009, 12:02:23 pm »
In software or DAC ? biglol
astacus21
« Reply #116 on: May 23, 2009, 07:29:28 pm »
hehe
Peter you dont have to wait so long...
If you wish to try w7 RC (build 7100) there is allready the language pack that transforms this version to NL. Search for this file
7100.0.090421-1700_x86fre_client_lp_2-GRC1CLP2_DVD.iso and just extract it and install.
« Reply #117 on: May 23, 2009, 10:31:47 pm »
Just send you email.
With language packs,
Maybe it works.
Thnx for that astacus21!!
Grtz roy
or here http://www.filemail.com/dl.aspx?id=QBACSVCDUJJVZAV
« Reply #118 on: May 23, 2009, 11:20:30 pm »
Ugh,
Looks like I have to put W7 on the new pc.
But, Roy which DAC are you using? If that's the x-fi (which i have on my gaming pc), the difference in sound between vista and w7 is likely the cr*ppy creative drivers...
« Reply #119 on: May 24, 2009, 12:01:44 am »
Yes, you could be right, but the difference is hugh, with Vista on SSD sounds very cr*ppy.
So, thats why I choose W7
Find out for your self.
I ain't that happy with the soundcard, but rather wait for Peter's super-duper NOS1 DAC.
Instead of investing in new card.
