November 23, 2024, 12:36:51 pm *
Pages: 1 2 3 [4]  All
Author Topic: 9w-2 does not work help!  (Read 44765 times)
« Reply #45 on: November 17, 2008, 06:47:14 pm »
GerardA,
1. I can't judge about problems in earlier versions because ... well ... there are newer versions. That we currently want to listen to an older version is bad luck for a while.
2. Please don't use Core Appointment for a while, so you can prove it is just that (but maybe you already know). But whatever you can prove, I'm afraid I can't help with it, or solve it. Of course, when more people have problems like this I must get cautious. Happy
« Reply #46 on: November 17, 2008, 07:13:21 pm »
I was just thinking ... yes
Core Appointent can not be done for drivers (actually I wish it could -> with registry hacks it can I think). Now what if your system allows for this (one is enough) while it actually "can't" (or conflicts) ...
I don't think you can do much with this information, but it might be a reason.
beto
« Reply #47 on: November 17, 2008, 07:24:56 pm »
It is a ma78gpm-ds2h and replaces a ma78gm-s2h
GerardA,
Oh my god!  I have the same exact board ma78gpm-ds2h and my son has the other one ma78gm-s2h  Wink
they both run good, and we have no issues with them, we are also overclocking them! and they are stable.
my son uses his to watch bluray movies...
On my PC I have switched back to version 9v-6a... as the gentleman on the other thread had mention it to be better,
which I do indeed I can feel the difference in soundstage and dynamics.
 we are happy with these boards thus far and we are using the phenom processors.
beto
« Reply #48 on: November 17, 2008, 08:58:17 pm »
Which powersupply is recommendable, soundqualitywise..?
I am not sure about this, being that there are sooo many power supplies to choose from at the store, even within the same wattage ratings, for a certain price range, I usually pick the heaviest I can find within a certain price range, that tells me the heat sinks are beefier and are able to handle current loads better, ussually.. but it does not tell me if the filtering circuits are any better, a chance I have to take. I use a 430w, which seems enough for what I do.
« Reply #49 on: November 17, 2008, 09:25:59 pm »
Beto,
That's good to hear!
I think the DS2H sounds better but with all the changes happening here I try to be cautious in my judgment.
Now I am very curious what core appointment you are using?
Maybe it's time to upgrade to a phenom. But I like the low wattage of the 4850e, it works with a passive cooler, I'm afraid a phenom needs a fan.
And I hate the noise my old XP-pc is making. (5 fans to keep the pentium-D below 80 degrees)
For now I'm listening with no core appointment, like before.
Fairport Convention, lot of detail but Sandy Dennie's voice sounds a bit thin now.
beto
« Reply #50 on: November 18, 2008, 11:42:02 pm »
I am not using core appointment, as that capability is disabled with the free version, I think.. and I don't understand it very well, when I listen to XX I usually don't do much with my PC.. I just tap my feet with the tunes.. Happy...
The phenom came with a fan and I use it, thou, thus far, it has not bothered yet. but agree, not having fans at all is a plus for what we do...
