November 23, 2024, 01:17:48 pm *
Pages: 1 [2] 3 4  All
Author Topic: 9w-2 does not work help!  (Read 44781 times)
Leo
« Reply #15 on: November 09, 2008, 07:09:20 pm »
Hello Peter,
the AA problem is solved. Playing now!
Leo
« Reply #16 on: November 10, 2008, 07:01:43 pm »
Guys,
Since I don't get a response so far from beto, is there anyone else who gets the "Path is not of a legal form" error when using FLAC files ?
or the other way around :
Is there anyone besides me who does NOT receive that error and can just plat FLACs ?
I actually want to upload an upgrade because of some annoying bugs solved, but since this one would be the most annoying one (especially when everybody has it) this is of not much use ...
(it is not neccessary to download the zip from my before post in order to give the answer)
« Reply #17 on: November 10, 2008, 07:34:32 pm »
Guys,
I am not sure if i am the right one to answer this... At the moment i do not have such... As i said i have had it sometime's when i upgrade.... I alway's thought it was something i did wrong... And pressing stop and start again solved it. I never had it during normal playback. (meaning the way you describe it.)
At the moment attended playing errorless....
beto
« Reply #18 on: November 11, 2008, 02:42:26 am »
Hey Peter, sorry I have not been able to get to you any sooner, I downloaded your fix, but unfortunately, I have the same problem, but this time I got a new message with more detail. attached is the log file and the new error message.  I don't know what to tell you. maybe next version I'll have more luck.. also I did try older versions of the program and they work with flac files.
* XX-20081109-082816.log (19.17 KB - downloaded 505 times.)
« Reply #19 on: November 11, 2008, 07:12:27 am »
Ok thanks. The log file shows it all. What I see is quite unexpected though.
Is it true that you don't have a multi core processor ?
« Reply #20 on: November 11, 2008, 05:40:40 pm »
Uhhmm ... Is it true that you have a double quad core processor ?? this would be the explanation ... yes
beto
« Reply #21 on: November 11, 2008, 05:41:57 pm »
Nope, I have a triple core processor, it's the AMD Phenom 8450 Toliman 2.1GHz 3 x 512KB L2 Cache 2MB L3 Cache Socket AM2+ 95W Triple-Core Processor. which is awesome in my view.... with 2 gigs of ram and Vista 32bit SP1... If that helps.
beto
« Reply #22 on: November 11, 2008, 05:45:47 pm »
I am thinking in getting a quad core processor.... Happy but it all depends on what Intel comes out with this year...... thanks.
« Reply #23 on: November 11, 2008, 05:50:31 pm »
Whaaaat ?!?! So that's why. I never knew that. So I anticipate on 1, 2, 4 and now 8 by treating that as 4.
Note that this influences the Processor Core Assignment (hence sound quality) just the same ! Meaning : currently that won't work for you either and there will be no difference in those settings for you now.
Anyway, problem virtually solved, and apparently a kind of each number should be supported.
Never too old to learn, Happy
beto
« Reply #24 on: November 11, 2008, 05:59:58 pm »
hahahaha!... Yeap, it's a new proccessor it multitasks as good as a quad... I don't understand?  you say that, that won't for me either?
what won't work?
when I play wav files it sounds awesome... it just fails with flac and mp3s, or I am not understanding what you mean, I thought the problem may be related to conversion from flac to wav or mp3 to wav?
« Reply #25 on: November 11, 2008, 06:12:05 pm »
No no no, the problem you have currently indeed is related to the conversion, and is solved here now.
But I tried to warn you for the Processor Core Appointment setting (Settings Area) which won't do anything for you other than "normal". When it works as intended (must fix that now), you will be able choose from 4 appointment settings, one of them being the playback thread (process) dedicated to one core, and all of the other stuff in the PC to the other cores. So, you *can* make the setting, but won't notice any difference in sound, because I don't deal with the 3 core processor (didn't know it exists). When it works you sure will be able to hear the difference, although I can't advise you about the needed settings (differs per setup; I use setting 3).
beto
« Reply #26 on: November 11, 2008, 06:56:13 pm »
Good to know that you will fix it, (if not already fixed).. and I am also wowed to know that with core appointment I can reach a higher level in sound quality.. wow, I thought the way it is sounded good, now you have got me interested.. Uhmm... Happy
beto
« Reply #27 on: November 11, 2008, 07:06:34 pm »
Alright Peter, I will test your new version as soon as you put it out... though, I enjoy very much the other version that works.. Definitely your player it is one of the best if not the best player I have used on my PC.. Thank you for doing such a good work and making me enjoy my music that I had not listen to for a long time.. you revived my desire to enjoy audio again in quite a while..
Cheers..
beto
« Reply #28 on: November 12, 2008, 03:11:40 am »
FYI- I just played a couple of flac, mp3 and wav files with 09w-3 and they work good on AMD 3x processor!
But still why older versions had no problem at all. though it doesn't matter much, I guess..
Great!    Grin
Thanks.
« Reply #29 on: November 12, 2008, 08:38:28 am »
Because since 0.9-w the conversions are allowed to run in several "threads" (self containing processes). Each such a thread runs on its own core (otherwise it would be useless). The advantage : with two cores the conversions run twice as fast, with 3, three times as fast, with 4 or more, four times as fast.
Since 3 wasn't recognized as an existing situation, it just went wrong (though with that strange message which indeed normally is dedicated to old Visual Studio References and the like, so Google didn't help me at all on this one nea).
