April 06, 2025, 06:28:58 am *
Author Topic: Buttons Shorcut Letters  (Read 7327 times)
andy74
« on: October 31, 2008, 11:08:44 am »
I have a small request.
two buttons "&Play and "&Pause" have the same shortcut letters "&P".
Can you please change the letter for Pause to something else.
I believe it would be a simple change.
Thanks
Andrey
« Reply #1 on: October 31, 2008, 02:29:38 pm »
That they have a shortcut at all is a pure coincidence. I never payed attention to it, and the double P probably came from copying one to the other.
Since it is about time now (meaning this weekend) to start the remote control stuff, I will be solving it for that reason already.
In the mean time, if someone has ideas about what shortcut should be applied to what button (e.g. because it is a standard for players -> I just never looked into it (yet)), please step forward.
Btw, keep in mind (although I'm not sure why yet) that we will be remotely controlling a player which actually isn't there in the case of Unattended Playback. Another challenge ...
LydMekk
« Reply #2 on: November 02, 2008, 05:20:35 am »
Ah...nice. Soon no need for me to fish around for the mouse in the dark listeningroom...  Happy
Looking forward to using only keyboard keys like F=Forward, B=Back (track skips), P= Play etc. Of course talking about Attended playback...no idea how you're going to solve unattended with no focused program running. Unsure if there's a standard for these keys, why don't you look at what MS MP 11 is using and use that as a standard. Then there's no need to reprogram MS's standard remote control system etc.
Goodie! Remember back in the "stoneage" where I requested this, P!  prankster
In the norwegian version from MP 11's help file under shortcuts etc.:
Hvis du vil
 Bruk denne hurtigtasten
Zoome til 50%
 ALT+1
Zoome til 100%
 ALT+2
Zoome til 200%
 ALT+3
Skifte visning til video med full skjerm
 ALT+ENTER
Spore skrittene dine tilbake gjennom de siste visningene dine i spilleren
 ALT+PIL VENSTRE
Spore skrittene dine fremover gjennom de siste visningene dine i spilleren
 ALT+PIL HØYRE
Bytte til fullskjermvisning
 CTRL+1
Bytte til skallmodus
 CTRL+2
Bytte til den første visningen i en mediekategori etter Nylig lagt til (f.eks. Artist i Musikk)
 CTRL+7
Bytte til den andre visningen i en mediekategori etter Nylig lagt til (f.eks. Artist i Musikk)
 CTRL+8
Bytte til den tredje visningen i en mediekategori etter Nylig lagt til (f.eks. Sanger i Musikk)
 CTRL+9
Forrige (element eller kapittel)
 CTRL+B
Sette fokus på søkeboksen i biblioteket
 CTRL+E
Neste (element eller kapittel)
 CTRL+F
Slå på eller av tilfeldig avspilling
 CTRL+H
Løse ut en CD eller DVD (merk at dette ikke fungerer på datamaskiner som er utstyrt med to eller flere CD- eller DVD-stasjoner)
 CTRL+J
Vise eller skjule de klassiske menyene (menylinjen) i standard modus
 CTRL+M
Opprette en ny spilleliste
 CTRL+N
Åpne en fil
 CTRL+O
Spille av eller sette på pause
 CTRL+P
Stoppe avspillingen
 CTRL+S
Slå på eller av gjentakelse ved lydavspilling
 CTRL+T
Angi en URL-adresse eller bane til en fil
 CTRL+U
Lukke eller stoppe avspilling av en fil
 CTRL+W
Spole tilbake video
 CTRL+SKIFT+B
Slå på eller av teksting og undertekster
 CTRL+SKIFT+C
Spole fremover i video eller musikk
 CTRL+SKIFT+F
Bruke rask avspillingshastighet
 CTRL+SKIFT+G
Spille av ved normal hastighet
 CTRL+SKIFT+N
Bruke langsom avspillingshastighet
 CTRL+SKIFT+S
Gi et element som avspilles, klassifikasjonen null stjerner
 CTRL+Windows-tast+0
Gi et element som avspilles, klassifikasjonen én stjerne
 CTRL+Windows-tast+1
Gi et element som avspilles, klassifikasjonen to stjerner
 CTRL+Windows-tast+2
Gi et element som avspilles, klassifikasjonen tre stjerner
 CTRL+Windows-tast+3
Gi et element som avspilles, klassifikasjonen fire stjerner
 CTRL+Windows-tast+4
Gi et element som avspilles, klassifikasjonen fem stjerner
 CTRL+Windows-tast+5
Gå tilbake til standard modus fra full skjerm
 ESC
Vise Hjelp for Windows Media Player
 F1
Redigere medieinformasjon på et merket element i biblioteket
 F2
Legge til mediefiler i biblioteket
 F3
Bytte visning av elementer i detaljruten med alternativene som er tilgjengelig med knappen Vis alternativer
 F4
Oppdatere informasjon i rutene
 F5
Øke størrelsen på albumgrafikk
 F6
Redusere størrelsen på albumgrafikk
 SKIFT+F6
Koble ut lyden
 F7
Redusere volumet
 F8
Øke volumet
 F9
Vise klassiske menyer (menylinje)
 F10
Bytte til fullskjermmodus
 F11
« Reply #3 on: November 02, 2008, 09:21:52 pm »
How bout keeping it the same as what foobar does ... eventually we'll win these fools over with better SQ, but let's make it easy to transition.
