April 08, 2025, 10:37:22 pm *
Author Topic: W1 does not play.  (Read 12631 times)
« on: October 20, 2008, 02:27:57 pm »
W1 does not work. Right after press play this error comes up. Slider does move and for 1 sec i hear music. right after that nothing. With a new track the same error apears. And the slider moves like there is noting wrong.
grtz
« Reply #1 on: October 20, 2008, 03:01:01 pm »
Hmm ... In the Settings Area there's a disabled field "Split large files". I assume that's on 2500 ?
Furthermore, are you sure you upgraded all files ? Please look at the date of XXEngine3.exe. It should be from yesterday.
« Reply #2 on: October 20, 2008, 03:22:37 pm »
I just checked xxengine3 and that is from the 19e. But now it does play..... When i downloaded w1 and put in the new code there is no problem. see w3 down below. But when i put the new file's in the old map containing the version before this one, than w2 is shown and it will not play.
Strange thing is that where you talk about 2500 in the disabled field there is 0 in pic w2 and 700 in w3.
so w2 did not play
    w3 did play
grtz
« Reply #3 on: October 20, 2008, 03:44:42 pm »
This is the most weird ...
The 0 (instead of 2500) I already was afraid of (couldn't test this properly), but where the heck the 700 comes from ?? if it weren't that I used 700 at some stage for a default I'd say it's random. But I *did* use 700, and now you have that.
Ok, even with 700 it won't work. You may think so, but it will go wrong at some stage.
I'm afraid I'll have to put up a new version ...
Thanks Gerard.
PS: I think this goes wrong somewhere at answering Yes to "Load previous settings". So, it does that, but obtains 0 because officially the feature is already in there all the way, but doesn't work properly. The default of 2500 (as how it's put in there) is thus overwritten by your "yes" answer.
That still doesn't explain where the 700 comes from, but I guess that's somewhere "hard coded" in the program due to testing.
« Reply #4 on: October 20, 2008, 04:19:20 pm »
I tried to go back and do it all over again (Say no to the question load previous settings) but the question Load previous settings does not come again. unhappy
Even tried to install a fresh v7 with new code. and than put w1 in there. But nope....
Dammn Vista with 10 min copy..... aggressive
« Reply #5 on: October 20, 2008, 04:22:17 pm »
That's what I meant ... it is such a tough job to test this properly. And I didn't succeed apparently.whistle
« Reply #6 on: October 20, 2008, 06:01:16 pm »
2500 it is..... And playing..... Happy
Grtz.....
« Reply #7 on: October 21, 2008, 10:11:01 am »
What a difference a day makes ( .. and a new version .. hehe )
I was tearing my hair our yesterday trying to figure out why I was getting multiple instances of ChangeWP appearing in task manager and every track only played for exactly 10 seconds then went silent, with the progress bar continuing.
Happy to report though that 0.9w-1a is behaving as intended as I really like the almost instant start of the first track in unattended mode now  Happy
One small glitch I have noticed ( and I'm still trying to see if there is a pattern ) , is that occassionally I get the wrong jpeg appearing in the left panel. When the wallpaper is produced everything is as expected, so I'll continue to monitor. It may well be the folder structure of my galleries.
Thanks for this new version Peter  very happy
« Reply #8 on: October 21, 2008, 01:36:21 pm »
Russ,
Yesterday I noticed the same myself. Not really "wrong" as such, but merely not updated.
I will look into that.
