April 07, 2025, 12:03:20 am *
Author Topic: XXHighEnd does not open in XP  (Read 8411 times)
werner
« on: June 11, 2007, 06:10:07 pm »
Hi Peter
After enjoying XXHighEnd a while on my lapttop with Vista, I tried to install it on a PC with windows XP. So I first installed windows (it only had linux) and downloaded xxHighEnd. As soon as I try to open the program windows shows: 'kan de toepassing niet initialiseren (0x0000135)
klik OK om te toepassing te beeindigen'. And that is it, no XXHighEnd, no music   aggressive
Do you have any any idea how to solve this ??
thank you in advance
Werner
« Reply #1 on: June 11, 2007, 07:30:07 pm »
Hi Werner,
So did you do the things in here : http://www.phasure.com/index.php?topic=11.0 ?
werner
« Reply #2 on: June 12, 2007, 08:55:51 am »
Thanks for that Peter,
I did already part of that but clearly not enough.
After struggeling an evening with service pack 2 and the links you posted, XXHighEnd works under windows XP (on a machine with only about 0,6 Gb RAM). I had no time to listen long but from what I heard (with engine 2 and double) it seems better than under Vista on my MacBook. After good listening I'll let you know some more in another topic.
Werner
