November 23, 2024, 02:51:52 pm *
Author Topic: Cover art and playlists  (Read 5878 times)
Fidelio
« on: September 25, 2008, 10:24:34 am »
When you play a playlist consisting of different songs from different albums, the cover art in the left pane doesn't change when the song changes. One has to manually click the song to change the cover. Perhaps this could be fixed?
- Cantatis Overture
- Naim amps
- Wilson Benesch speakers
- Chord Co. cables
« Reply #1 on: September 25, 2008, 01:32:54 pm »
Ha ! Thanks for reporting this. Gerard had similar, and the way I solved it made me believe it wasn't solved. Also, back then I could not copy that behaviour. Now I can ...
Btw, it requires playing FLAC or MP3.
It is solved now, and will be contained in the upcoming version.
