November 23, 2024, 08:04:00 pm *
Author Topic: Its very good  (Read 34555 times)
Jack
« Reply #15 on: June 17, 2007, 03:29:06 pm »
Chris
Where are your wavs stored, local or network drive?
Jack
« Reply #16 on: June 17, 2007, 04:51:50 pm »
That can't matter Jack.  no
Bert, why can't (or don't) you tell what you did with upgrading your mobo drivers ? ...
« Reply #17 on: June 17, 2007, 05:12:30 pm »
Where do you normally get the latest drivers from? And if you have downloaded them, how did you upgraded?
For me obvious and therefore no reason to explain any further...???
Jack
« Reply #18 on: June 17, 2007, 05:44:46 pm »
I was getting dropouts over a network. I resolved this by turning off auto negotiate in the network card properties & reducing the speed. It worked for me!
Jack
« Reply #19 on: June 17, 2007, 06:29:29 pm »
Oh yes, I've heard something about not using the GB speed of a network card. And, sure this may help (if better drivers are not at hand). But it just can *not* be caused by the tracks being read over the network ... they are loaded into memory first you know ...
Theoretically that can bother you right at the end of a track (when a next one is loaded), but this would be impossible (to harm) throughout the playing track.
Again, generally -because something is interrupting processes- it can disturb, and then yes, throughout the playing track.
Better drivers ! (easy to say, right ? Happy)
Thank you !
Chris V
« Reply #20 on: June 17, 2007, 11:15:01 pm »
Hi guys
I have the wav files stored both on the C: drive and some on a USB flash drive. Same drop outs on each.
I do have difficulty finding the latest drivers (where to look) and also in knowing which of all my listed devices is the motherboard - nothing on the device manager is actually called a motherboard!
The drop-outs get worse as I increase the sample rate from 44.1. At 44.1 they are pretty rare, at 96 they are pretty common, and at 192 its almost unlistenable. This is a problem, as sound quality is improving with each increase in frequency. Incidentally my Tact is picking up the right signal all the way to 192.
What about setting XX priority higher how do i do this?
Sorry to be such a nuisance. unhappy
Thanks Chris
Then to SW1X Signature DAC
« Reply #21 on: June 17, 2007, 11:45:02 pm »
Oh, you're not. If *I* only knew how to help here. And you shouldn't do it on your own either ...
The fact that the dropouts increase at a higher samplerate -as you described it-  says enough I think. Do note that the upsampling comes right after XX and is done by the OS. Well, in your Vista case of course.
I'm not sure what to do with it (because it should be the drivers) ... but can you perhaps recognize that the dropouts occur each time at the exact same place (in a track) ? Again, dunno what to do whith it, but who knows something shedds a light ...
No ... this is about the various chips which  are on the mobo, and *they* need upgrading. But I really never done it.
Chances are high that #3 goes around your issue, but then first #3 has got to work at your systems.  Happy Note though that XX itself (which would be the case then) doesn't go higher than 88K2.
Just don't give up. Today I suddenly found solutions (C++) for things which I couldn't find for 4 months ...  yes
