April 08, 2025, 10:48:19 pm *
Author Topic: XXHighEnd Model 0.9v-6a (solves Logging bug)  (Read 7962 times)
« on: September 08, 2008, 12:14:37 am »
The logging facility which is there since 0.9v-7, caused some problems by itself.
A GDI+ error could come from it, and possibly playback parameters messed up for some.
This should be solved now.
In the mean time all references to "Galery" oops were changed into "Gallery".
Warning : This means that the "Reference Files" for Galleries are named differently as well and ... are expected to be named different than before. This means that when you rely on these reference files, hence want changed coverart (names) to get worked through to the Galleries they're in ... you have to rebuild the Galleries. sorry
* XXHighEnd-09-v6a.zip (3481.66 KB - downloaded 919 times.)
Page created in 0.014 seconds with 19 queries.
