November 23, 2024, 06:14:46 pm *
Author Topic: Fireface 400 settings  (Read 10314 times)
Chris V
« on: June 09, 2007, 07:11:56 pm »
Hi
Can someone paste a copy of their Fireface settings that are displayed when using XXEngine #2 with doubling.
I have set the buffer to 48 and the clock is showing Master mode and freq of 88.2 which seems OK.
The odd part perhaps is that I have 'no lock' in every area.
I need a reality check.
Cheers Chris
Then to SW1X Signature DAC
« Reply #1 on: June 09, 2007, 11:40:21 pm »
Buffer should be 128 to be on the safe side. 48 IMO just won't work at 88K2 (Doubling).
The Lock just won't be there because the PC as an input won't do that. Note that no lock is just okay.
Wether it's set as Master or not doesn't matter (it just will be -> same as no lock).
Oh, never mind the 48K in below settings ... just watched a movie ...  Tongue
Chris V
« Reply #2 on: June 09, 2007, 11:58:43 pm »
Spot on and sounding good good good good
Incidentally, what does happen if the buffer is too small - poor sound or something more dramatic?
« Reply #3 on: June 10, 2007, 12:40:30 am »
Ticks.
The lower the better the sound, until you went too far. So 128 is on the safe side, but 96 should do also.
64 may be too critical. 48 *is* too critical.
48 is allright for not Doubling.
So, you're good to go !
Chris V
« Reply #4 on: June 10, 2007, 12:59:18 am »
Yep, I had the ticks when playing with the settings. Now I know what caused it Wink
I'm happy now. Day off tomorrow, going on a meet for Triumph Bonneville m/cycles, then back on the XX on Monday good
« Reply #5 on: June 10, 2007, 01:06:44 am »
No, I leave the Triumph (car) in the garage, and go for a Subaru meet instead. very happy
Well, good Chris. Happy listenings !
Page created in 0.104 seconds with 19 queries.
