November 24, 2024, 11:54:30 am *
Author Topic: Galery info in left pane is not working fine.  (Read 7971 times)
« on: September 07, 2008, 10:08:26 am »
The galery info is not working fine IMO. When you are searching for a album and open a album that is beginning with the letter  D and that is not the one you where searching for and you like to go back you have to start with A again instead of going back to the D album's.
« Reply #1 on: September 07, 2008, 03:23:54 pm »
And maybe related to this: When I use the left library button I don't get all the tracks for the album, like a top50 with missing songs:
And when I select everything it doesn't play and after stopping I get a strange message.
When selecting one song it works. Found it... Different filetypes mixed in one directory..
(And everytime it says it can't find the "uitgever" and I have to convince Vista I trust you!)
« Reply #2 on: September 07, 2008, 06:41:53 pm »
When does this happen, and since when does this happen ?
Also, exactly which program is this about ?
« Reply #3 on: September 07, 2008, 07:17:33 pm »
I'll try to be more specific when it happens again, but it looked to happen with everything that got started, xxhighend. exe, xxhighend3.exe, wallpaper etc..
It happened after installing version v6, now listening and no problems, so I want to enjoy this before I start to mess up again.
BTW, WMA-files are not supported?? What is the way to go with them, maybe a good conversion tool?
« Reply #4 on: September 07, 2008, 07:40:59 pm »
No, WMA files are not supported at the moment. It will, but later. First I now want to finish off everything (which already will take "long" because of writing the manual yes).
Each conversion tool that can do it, will be good enough I guess. I would need to Google for it as much as you. So you better do it. Hahaha. Oops.
Page created in 0.104 seconds with 19 queries.
