November 23, 2024, 05:20:41 pm *
Author Topic: XXHighEnd Model 0.9v-5 (solves various errors during playback)  (Read 7815 times)
« on: August 31, 2008, 10:38:08 pm »
Well, hopefully this solves just all playback errors, except for the silent playing. But hopefully that's attacked in the next version.
  • The ChangeWP error shouldn't occur anymore. The way it is solved shouldn't cause anomalies, and it was not really tested (rather undoable because it may take 24 hours or more before it happens, and since it is theoretically solved ... when does it happen ?).
    Note that when the ChangeWP error occurred (during playback that is) as many of the same errors occurred after XX was quit and restarted. This now doesn't happen anymore either.
  • If all is right it will not happen anymore that a track which internally reports a wrong track length, errors in Engine#3. This was tested upon an album which was known to be wrong, and that works now.
    Please report if you still encounter any "XXEngine3.exe stopped working" !
  • Tracks shorther than around 14 seconds never could play. Now they do.
    On this matter, please report if you encounter any messages like "Engine#3 did not start within ..." !
  • Cue File albums caused "XXEngine3.exe stopped working" at the end of the last track (since March or so 2008) . Solved.
  • A check (with warning) has been built in for the album folders residing at least two folders under the root of a drive. Thus :
    d:\Music\Rock\[album name]
    and not
    d:\Music\[album name]
    This kind of guarantees better that the (various) CoverArt can be found.
Still no ToolTips on the new functions since 0.9v-4.
Issues found :
At the Show/Compare track function as can be found at rightclick at a Library Item, the last track of a Cue File album always shows the same running time as the before last track.
Also, the Embedded Explorer doesn't (always) do what was intended : not (!) showing the related data in the Library Area when only the arrow for expanding a folder was clicked. This should only happen when the folder itself is clicked.
* XXHighEnd-09v-5.zip (3473.77 KB - downloaded 743 times.)
Page created in 0.122 seconds with 19 queries.
