November 24, 2024, 07:28:24 pm *
Author Topic: Chk box not working for me  (Read 21863 times)
« on: August 29, 2008, 09:02:53 am »
Under Library tab, when I tick chk error says, "Not possible when chk not ticked"  I've kinda worked it out in my head that it thinks I'm ticking the Grp box ... which I haven't used/explored.  I want to tick the Chk Box to set up galleries.
« Reply #1 on: August 29, 2008, 11:43:52 am »
Hmm ... something's Fishy here indeed.
Will be solved in the next version.
Thanks for reporting !
« Reply #2 on: September 01, 2008, 06:33:15 pm »
scratching ... which I forgot ! sorrysorry
« Reply #3 on: September 07, 2008, 05:07:57 am »
I don't think I ever noticed the file playing but no sound stuff, glad you all worked that out.
Thanks for fixing Chk boxes ... all the check boxes show up when I tick that.
Now,
could you please fix Select all chk boxes
you're killing me and my new ultra expensive SSD, I can't make galleries
hehe
thanks peter
edit.  notice how I spell Gallery
« Reply #4 on: September 07, 2008, 06:47:06 am »
G'day SeVeReD,
you don't necessarily need the 'chk box' active to create your entries into the Gallery.
Leave the 'chk' box unticked, and perform your search function as normal to get the list of entries you want showing up in the middle library panel.
Select the first entry with the left mouse button so that it is highlighted. Use the scroll bar to go to the end of your listing, then, while HOLDING DOWN the SHIFT key, click on the last entry with the left mouse button. ALL the entries should then be highlighted. While they are all selected, click on the right mouse button and perform the "gallery/add to gallery" function.
Give that a try.
« Reply #5 on: September 07, 2008, 08:25:00 am »
G'day SeVeReD,
Give that a try.
Yes, this works out fine.  Thanks  Just about have all my galleries worked out and it is a good bit faster using the main SSD than always having to spin up the external drives just to do a search.
« Reply #6 on: September 07, 2008, 08:40:48 am »
I'd be interested in knowing how fast those SSD's are currently. If you have a moment, could you grab HDTUNE (v 2.55 ) from http://www.hdtune.com/ are run a quick benchmark on it. I'm particularly interested in its Average Transfer Rate and Access Time results. My Galleries are getting a big these days and I'm looking for ways of speeding up response also.
« Reply #7 on: September 09, 2008, 09:54:56 pm »
Hi Dave, anything known from this ? Ah, you are waiting until I mount mine hehe (which I still did not).
Also, I think you were implying that making GaLLeries with the checkbox method doesn't work (with 0.9v-5). But I tried, and it does here ? I tried it with LL of course ...
blink
« Reply #8 on: September 10, 2008, 04:23:15 am »
Says Transfer Rate Minimum is 71.6 and Transfer Rate Maximum is 115.1 MB/sec.   Average 103.6 MB/sec.
Access Time .4 ms
burst rate 122.6 MB/sec
CPU Usage 4.0%
The graphs slowly bounces up and down in a regular pattern.  Anyone know the name of the recommended program on here for taking screenshots?  This version of vista for xxhe doesn't even have word loaded on it for prtscreen.
« Reply #9 on: September 10, 2008, 04:53:06 am »
blink
Libray Tab
right click on an album
Select All (checkboxes)
Doesn't work for me. It only selects the one album I right click on... it doesn't select (tick checkboxes) all the albums.  I just tried it with 6 & 6a versions.
« Reply #10 on: September 10, 2008, 06:54:59 am »
Access Time .4 ms
CPU Usage 4.0%
Thanks for these results. For comparison, the fastest drive in my system, a WD 1TB SATA drive starts off at 92.3MB/sec transfer rate and drops to 41MB/sec ( presumably at the inner core ) giving an average of 73.3MB/sec. Its burst speed is 149.8 MB/sec. The access time though is where the huge difference occurs; the SATA drive averages 14.7 ms. There will be some variability due to system configuration/speed, but overall you have given a very sound argument for using a SSD for the galleries.
May I ask which brand and model did you choose?
Edit: I just found the model you bought (mentioned in an earlier post by yourself )
« Reply #11 on: September 10, 2008, 07:13:19 am »
blink
Libray Tab
You must select the range of albums you want to tick. So, first select those, then order for Select All (checkboxes).
Unselect All works the same, and *that* is not the most convenient; right now, this kind of makes you select - apply (to Gallery) - unselect all. Otherwise you won't get rid of the checkboxes anymore, or you don't know where you were, etc.
I'm working on a vast improvement in this area. Next version ...
« Reply #12 on: September 10, 2008, 07:45:28 am »
I discovered a flaw using the 'chk' box feature to create the galleries. If you have the 'chk' box ticked, and you use the procedure I outlined earlier to select all entries ( ie. highlight the first entry , scroll down to the last entry and while holding down the SHIFT key you click on that last entry ), that all the entries seem to sequentially have their additional artwork displayed in the right hand pane when the system is going through the process of highlighting all the entries. This REALLY slowed down the selection process and makes it unworkable when you have many albums to process. I therefore chose to NOT use the 'chk' box.
Have you found this to be the case on your system also Peter ?
I've been thinking ( dangerous I know .. LOL ), that perhaps the additional coverart etc. need not necessarily be copied over to the Gallery folders, but simply have only the folders.jpg there. This should significantly speed up the loading of the galleries I would think. I noticed there is a cross-reference file in both gallery and source folder now, so perhaps that could be used to involk the displaying of data ( from the source folder ) in the right pane when an entry in the centre pane is selected.
« Reply #13 on: September 10, 2008, 08:59:14 am »
Oh, I hoped you found that to be a nice slide show ? swoon
Yes Russ, I saw that too (only day before yesterday). That will definitely have changed in the next version.
I do this in order to keep the data disks shut down. So yes, that creates redundancy and a lot of problems for the developer, but I thought it's really  better. Of course you are right that the folder.jpg only would do a rather nice job already, but it is not that simple, because people may call that cover.jpg, front.jpg, tray.jpg and 20 more. So, it would shift the determination from real time to the moment the Gallery is created, and as you can image the software changes here and there (hence better have it real time). Besides that, you'd miss the additional coverart, unless the disks spin up again. Btw, not a real problem for me, but for the waiting for it (I think I have 8 now, and the subsequently spin up, not in parallel. That's 8 times 5-10 seconds ...
So yes, but these are for the maintenance of it all. So, when nothing comes up in between, in the next version this will be used for moving albums to other Galleries, show where an album sits, rename albums (the folder to it), changing these things outside of XX and then "repair", etc. Currently it is used to maintain the consistentlcy with the coverart as mentioned above. E.g. rename img002.jpg to folder.jpg from whichever angle (GalleryA, GalleryB, the orginal) and "redistribute" it (hence cover for the redundancy).
But Russ, please keep on coming up with your ideas in directions like these, because it is really difficult enough without using a database (which I so far tried to avoid).
« Reply #14 on: September 10, 2008, 09:31:25 am »
Thanks for the explanation of your logic here Peter. I can understand where you are coming from now, especially the desire to keep the source folder disks from having to spin up if idle. My gallery folders are getting quite large ( approaching 9GB in total ) so I'm looking for any means to reduce load time. I am systematically going through each folder.jpg to reduce them to an average 500x500 pixels ( which I find is a good compromise ) so over time I hope to reduce the load burden. It would help if I stopped buying more music too .. LOL
Page created in 0.263 seconds with 19 queries.
