April 19, 2025, 11:25:33 pm *
Author Topic: Hi Peter  (Read 16192 times)
Flecko
« on: August 16, 2008, 09:20:54 pm »
I made it and installed Visat Happy Congratulations to you player, the soundquality is realy good and better than iTunes! But I have some problems runnig it. I installed xx on two pc's with vista32 ultimate and on both I can't drag files into the playlist when I start xx as administrator. This doesn't happen when i start it just with "open". The other prob is that on on pc I get an error massege when I start in normal mode saying "Unhandled exception occured in your application...". So I can't use it on this pc at all unhappy
Thank you and greetings
Adrian
the complete error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UnauthorizedAccessException: Access to the path 'C:\Program Files\Filesxx-highend\LibraryData.txt' is denied.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
   at System.IO.File.Open(String path, FileMode mode)
   at XXHighEnd.XXHighEnd.XXHighEnd_Shown(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnShown(EventArgs e)
   at System.Windows.Forms.Form.CallShownEvent()
   at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
   at System.Threading.ExecutionContext.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
XXHighEnd
    Assembly Version: 1.0.3116.37736
    Win32 Version: 1.0.3116.37736
    CodeBase: file:///C:/Program%20Files/Filesxx-highend/XXHighEnd.exe
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.312 (rtmLHS.050727-3100)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Microsoft.DirectX.DirectSound
    Assembly Version: 1.0.2902.0
    Win32 Version: 5.04.00.2904
    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX.DirectSound/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.DirectSound.dll
System.Data
    CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
LogicNP.FolderView
    Assembly Version: 9.0.0.0
    Win32 Version: 9.0.0.0
    CodeBase: file:///C:/Program%20Files/Filesxx-highend/LogicNP.FolderView.DLL
System.Management
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Microsoft.DirectX
    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
« Reply #1 on: August 17, 2008, 02:15:23 am »
Hi there Adrian !
Assuming you want to drag from Explorer, the sequrity rights are not equal. Thus, when you start Explorer also with Administrator Rights, then it works. Better is to switch off UAC though. All is described here : Vista Users ... prepare yourselves ....
About the error ... this most probably has the same cause. In this case though, it looks like you may have Activated XXHighEnd with other (higher) rights than now, at playback.
If you applied the UAC thing above and this error still occurs, you could try to delete that folder, and install XXHighEnd again (with the UAC thing applied properly).
I hope this helps !
Flecko
« Reply #2 on: August 19, 2008, 03:23:01 pm »
Thanks Peter, I disabled UAC and now it works fine. Still one thing. XX doesn't remeber my settings, any idea?
Greetings Adrian
« Reply #3 on: August 20, 2008, 12:20:14 pm »
What I can imagine is that at startup you receive a message something like "Couldn't restore all settings" and then you can press continue or cancel. Now, when you press continue, the thing you have may happen. When you press cancel the problem should be over (but you will have to set the settings once from the start).
Does this help ?
Flecko
« Reply #4 on: August 25, 2008, 05:00:01 pm »
it was that simple thanks. I discovered another bug, wich is no prob for me but I like to help improving so I report. When I load files in the playlist and move the files afterwards into another folder, xx crushes direct at start with  a message that the folder doesn't exist.
« Reply #5 on: August 25, 2008, 05:31:21 pm »
Ya I've had this too.  I either have to move the folder back to the original place or "reinstal" XXHE and choose to redo settings.  Now I always remember to "clear" XXHE playlist before moving files.
« Reply #6 on: August 25, 2008, 06:20:31 pm »
I have mentioned this to Peter also. In the interim, you can get around the bug by deleting the "!CurrentlyPlaying.PLXX" file ( normally in your install directory) and restarting XXHE. No need to 'reinstall' everything.
« Reply #7 on: August 25, 2008, 07:19:17 pm »
Doh! should have looked for something like this before.  I'm too "got a problem... format!"
« Reply #8 on: August 27, 2008, 06:12:22 pm »
But can I ask what means "crashes" in this case ? When there's a message there's no crash.
Also, I think if you clear the Playlist Area after this message, the problem has gone. True ? Untrue ?
It is true that Russ told me this, but I can't invoke a real error, apart from a normal one, which then can be avoided (press CLEAR).
Btw, I don't think you would want me to remove those tracks from the Playlist that are not there anymore. You wouldn't understand ...
PS: If I am right about the CLEAR and all helping, I could make the message (which now is a system message really) more clear, including a hint what to do (or make the non-existing tracks highlighted, leaving you to right-click and Delete from Playlist). But I sense that you mean something different. Russ ?
« Reply #9 on: August 28, 2008, 04:04:59 am »
I'm recalling a time on the laptop when it happened.  The message would pop up saying it couldn't find the ?file; when I clicked ok to clear the message, XXHE would close too.  Not given a chance to clear playlist.
« Reply #10 on: August 29, 2008, 04:29:41 am »
Upon starting 0.9v-3a, if the path specified in the most recent playlist ( !CurrentlyPlaying.PLXX ) was no longer valid, the program would bring up an error condition window and request for the program to be closed. It was necessary to delete that playlist entry before XXHE would stay up and continue as normal.
With 0.9v-4, that same condition now brings up a different error message window titled "Show CoverArt" and says "Could not find a part of the path 'X:\XXXXXXX\XXXXXXX' etc. Clicking on the OK button now allows you to access XXHE as normal and you can then click on the 'clear' button to remove the entries in the current playlist. This solution has effectively solved the bug seen in 0.9v-3a.
Thanks Peter.
Flecko
« Reply #11 on: September 01, 2008, 10:04:32 pm »
Yes it is like this. I tried it once more this time with 0.9v-4. The only thing that still happens is vista telling that engine3 stopped working and asks if this program should be closed. After selecting "close" you can use xx onward.
Greetings Adrian
« Reply #12 on: September 01, 2008, 11:53:14 pm »
Hi Adrian,
Just after you bring up XXHighEnd again ? I just cannot imagine this combination. For esample (*if* related at all) ... if you don't select "close" for XXEngine3, you would be able to use XXHighEnd anyway. Both are not related by any means. Please allow me to say (and no offence meant !) : this cannot be true. However, you must be dealing with something here I gues ...
Flecko
« Reply #13 on: September 14, 2008, 12:46:38 am »
I tried it once again with the newest version 0.9v-6a. It is still like that: drag file into the playlist, play the file...everythings ok. close xx and move or delete the file. Start xx again. Then select the file and click play...error accured engine3.exe stops working...try it if yo don't beleave me.
Greetings Adrian
« Reply #14 on: September 14, 2008, 09:24:49 am »
Ah ...fool ... I only now understand what's actualy happening. You're *playing* ...
Yes, of course. Never thought about that. And if you then see that I was building the log the other day, including the message "Music file found" (you can see it in there), and I was overthinking that maybe there should be an official check for that in the program, because it wasn't there ... *and* I was thinking : nah, that can't go wrong because it was just checked by XXHighEnd ...fool
Will be solved in the next version Adrian.
